Non rigid tapping
  • klopp
  • Topic Author
  • Senior Member
  • Senior Member
5 years 2 months ago #217574 by klopp
Non rigid tapping was created by klopp
Hello,
I have a CNC without a spindle encoder and I want to cut threads.
I use a spring loaded tap holder, to compensate for inaccuracies, however I'm not able to generate the proper gcode for it.
I use Fusion 360 with the LinuxCNC postprocessor and I have tried every threading option there is in Fusion, but it always generates a G33.1 code, which is obviously not working.
Is there a way to generate GCode for non rigid tapping?
Thanks in advance
5 years 2 months ago - 5 years 2 months ago #217868 by andypugh
Replied by andypugh on topic Non rigid tapping
I think that you would need to either edit the G-code to use G84 or edit the postprocessor to use G84.
linuxcnc.org/docs/2.8/html/gcode/g-code.html#gcode:g84
Looking through linuxcnc .cps files on Github I don't see any mention of G84 (or even 84)
You can edit the cps directly from the Fusion interface (manufacturing -> management section) . You might need to save a copy to "my posts" before being able to edit it. Look for
case "tapping":
In the version I am looking at the change would be to line 1008 of linuxcnc.cps
Last edit: 5 years 2 months ago by andypugh.
Time to create page: 0.038 seconds
