Fusion 360 - EMC Post ?
5 years 4 days ago - 5 years 4 days ago #224592 by Pauchuk
Replied by Pauchuk on topic Fusion 360 - EMC Post ?
Ok, seems that on one of PC` s there is g64 option and on other one - there isnt one. How can I add it?
I thought same Fusion profiles share same settings, no matter on what PC I use Fusion.
Last edit: 5 years 4 days ago by Pauchuk.
5 years 4 days ago #224603 by andypugh
Replied by andypugh on topic Fusion 360 - EMC Post ?
Are they both set up to use exactly the same postprocessor?
5 years 4 days ago #224606 by Pauchuk
Probably no.. is there a chance to add g64 option?
5 years 3 days ago #224629 by db1981
Replied by db1981 on topic Fusion 360 - EMC Post ?
Hello,
the post proccecors and setting are local in the standard settings.
You have to change to cloud-post proccesorcs, in your settings to get it the same on every pc.
5 years 3 days ago #224667 by gunrak
Replied by gunrak on topic Fusion 360 - EMC Post ?
I have the very same problem as Pauchuk has, my inside corner radius is way of. I did not change anything in my workflow, neither I had similar issues before. I never paid attention to G64 in g-code.
What I can see is that Fusion recently updated UI during post processing, and today was the first time after update when I actually used post processor and router.
Like I said I did not pay attention was there G64 in greeted code before or was not, but I am sure that I can't find it now.
Could someone confirm that latest Fusion 360 Post processor works as it should?
Please see attached g code straight from post processor
5 years 3 days ago #224677 by gunrak
Apparently default Fusion 360 post processor never added G64. It might be coincident that only now I faced the issue. I updated latest Fusion's post processor with G64. Credits spangledboy.Please see attached file. Post processor is not tested in real life, but G code looks ok, will test it tomorrow.
Time to create page: 0.080 seconds
