- GCode and Part Programs
- CAD CAM
- Post Processors
- Fusion 360
- lathe moving in inverted direction while jogging direction is correct.
- Thank you received: 4149
14 Jan 2023 12:19 #261933
Replied by rodw on topic lathe moving in inverted direction while jogging direction is correct.
Not specific to lathes, but without touching off somewhere inside the machining envelope, there is insufficient room for the tool (eg to move the cutter to the surface) takes it out of bounds. This is where G54 touchoffs solve the problem. It is a breath of fresh air when you adopt a G54 strategy with touchoffs...
ref:
linuxcnc.org/docs/2.9/html/gcode/coordin...ha:coordinate-system
ref:
- smc.collins
- Thank you received: 139
14 Jan 2023 23:48 #261995
by smc.collins
Replied by smc.collins on topic lathe moving in inverted direction while jogging direction is correct.
for some reason g53 is being sent to 830 and 1150mm resepctively, for a unknown reason. I already have a email in with them about why this is ?
- JPL
- Thank you received: 118
15 Jan 2023 02:36 #262008
by JPL
Replied by JPL on topic lathe moving in inverted direction while jogging direction is correct.
The following user(s) said Thank You: smc.collins
- smc.collins
15 Jan 2023 21:01 #262063
by smc.collins
yeah, I set them to zero and they still call out to max travel, I have a email in about it.
- CAD CAM
- Post Processors
- Fusion 360
Time to create page: 2.328 seconds
