Could be any number of things burping or causing interference I s'pose; the OptiPlex control computer, Mesa 7i76E, VFD,I dunno. Appreciate your input. The control computer and its accompanying keyboard are in the neighborhood of 3 feet, possibly a smidge more from enclosure, VFD and it's main cable.A few years back i had one such case where the machine would go into e-stop while working very rarely, this was a plasma CNC with parallel port control, turned out keyboard being near the main torch cable triggered it.
Removing keyboard and mouse cables as far from spindle and mains cables as a starting point, maybe...
I will certainly do as recommended. Since the anomaly occurred twice, two different programs, it could be that it is easily repeatable. Fun fun fun. Appreciate the guidance.No immediate idea why it quit, but a helpful tool to debug is to run LCNC from the terminal. Leave the terminal open in the background and if/when it stops you can check the terminal output.
The output may be cryptic when/if it vomits, but you can copy/paste the output - at least the last few lines before it stops - and paste it here.
