- GCode and Part Programs
- CAD CAM
- Post Processors
- Fusion 360
- Added Display Message from Fusion 360 Post Processor via ManualNC
- Ritterchen
- Thank you received: 18
12 Apr 2024 10:58 - 14 Apr 2024 02:22 #298072
by Ritterchen
Added Display Message from Fusion 360 Post Processor via ManualNC was created by Ritterchen
Hi together,
as I use LinuxCNC with Fusion 360 as Post Processor for professional use I have some setups that require some special attention.
In Fusion 360 you can add ManualNC operations such Display Messages (as well as Stops, Tool Break Control and various other Operations).
I used it to display a warning message at the beginning of each operation to check if the fixture is correctly setup.
Here a short snippet of code that was needed in the Post Processor of Fusion to enable the output to LinuxCNC
Added below: "function writeBlock() {"
Added somewhere:
The full list of options can be created as case-statements as shown here: cam.autodesk.com/posts/posts/guides/Post...Training%20Guide.pdf
Page: 6-198
Credits by: forums.autodesk.com/t5/hsm-post-processo...ommands/td-p/8904847
Hope this eases up some of your processes with posting from Fusion 360!
// Process Manual NC commands executeManualNC();Added somewhere:
/** Buffer Manual NC commands for processing later */ var manualNC = ; function onManualNC(command, value) { manualNC.push({command:command, value:value}); } /** Processes the Manual NC commands Pass the desired command to process or leave argument list blank to process all buffered commands */ function executeManualNC(command) { for (var i = 0; i < manualNC.length; ++i) { if (!command || (command == manualNC.command)) { switch(manualNC.command) { case COMMAND_DISPLAY_MESSAGE: // sample on explicit execution of Manual NC command writeComment("debug, " + manualNC.value); break; default: expandManualNC(manualNC.command, manualNC.value); } } } for (var i = 0; i < manualNC.length; ++i) { if (!command || (command == manualNC.command)) { manualNC.splice(i, 1); } } }The full list of options can be created as case-statements as shown here: cam.autodesk.com/posts/posts/guides/Post...Training%20Guide.pdf
Page: 6-198
Last edit: 14 Apr 2024 02:22 by Ritterchen.
The following user(s) said Thank You: andypugh
- Thank you received: 4658
20 Apr 2024 05:05 #298708
Replied by andypugh on topic Added Display Message from Fusion 360 Post Processor via ManualNC
I tried fixing the word wrap in the code block, but couldn't work it out.
- Ritterchen
22 Apr 2024 01:49 #298817
by Ritterchen
Replied by Ritterchen on topic Added Display Message from Fusion 360 Post Processor via ManualNC
Hi Andy, the word-wrap is handled for me via Gmoccapy (2.9) that moves it into readable blocks. Did you implement it on Axis?
- CAD CAM
- Post Processors
- Fusion 360
Time to create page: 0.631 seconds
