it took me a few days of reading and playing but i got it working even with CSS , in the properties tab you can now define you highest speeds for the ranges and fusion will automatically output the desired M code , im used to old mastercam posts but getting the hang of fusion.
once i figured it out this was fairly easy to setup using some bits from an okuma post , you can add as many gears as needed.
here is my current linuxcnc post, setup to switch between 3 gears based on defined speeds in the property tab , puts G43 at every tool change , properly posts G28 , working CSS (selects high gear) , several other changes im forgetting.
download the text file and change to .CPS , i am not responsable for your machine.
