gmoccapy tool change issue after apply
10 years 8 months ago #69379 by newbynobi
Replied by newbynobi on topic gmoccapy tool change issue after apply
I found out, that the strange behavior comes from the gladevcp tooledit_widget.
It has archived several changes in master, but 2.7 is fine.
So I work around could be downgrade to 2.7.
I mailed already to the developers list and ask Chris Morley and Balestrino to review there changes.
I'll keep you informed.
Norbert
10 years 8 months ago #69384 by cmorley
Replied by cmorley on topic gmoccapy tool change issue after apply
Norbert
Did you test with Jessie or wheezy?
Chris M
10 years 8 months ago #69389 by newbynobi
Hallo Chris,
with both, the tool table disappears on both installs.
As far as I found it is related to the wear offset stuff.
Norbert
10 years 8 months ago #69390 by cmorley
k thanks
10 years 8 months ago #69402 by cmorley
I have pushed a fix to master.
There was a line commented out when i should not have beem
Chris M
The following user(s) said Thank You: 10K
10 years 8 months ago #69461 by 10K
Replied by 10K on topic gmoccapy tool change issue after apply
I downloaded the two files
tooledit_gtk.glade
tooledit_widget.py
from
https://github.com/LinuxCNC/linuxcnc/tree/master/lib/python/gladevcp
and overwrote the files in
/usr/lib/python2.7/dist-packages/gladevcp
That fixed the problem!
Thanks for the quick fix.
Moderators: newbynobi, HansU
Time to create page: 0.240 seconds
