Newbie setup Gmocappy setup
21 Oct 2015 16:54 - 21 Oct 2015 17:01 #64039 by cncbasher
Replied by cncbasher on topic Newbie setup Gmocappy setup
i can make a new post processor for you for aspire( which ver of aspire ?) sometime this week , so dont worry , just be sure it's all connected and working first
[TOOLSENSOR]
X = 10
Y = 10
Z = -20
these are changes are part of the ini config file edit to suit
in Traj section for working in mm make sure LINEAR_UNITS = mm
also change
[RS274NGC]
RS274NGC_STARTUP_CODE = G17 G21 G40 G43H0 G54 G64P0.005 G80 G90 G94 G97 M5 M9
Last edit: 21 Oct 2015 17:01 by cncbasher.
21 Oct 2015 17:01 #64040 by Stonefire
Replied by Stonefire on topic Newbie setup Gmocappy setup
Hi CNCbasher
Oh, you're an angel !
I'm patient....
Something is change from the original setup-files I've send you. I believe the machine-coordinatesystem is changed. Before it was measuring in mm. Now it is in very small numbers. I believe it must be inches, but not sure.
I've found unitsetup in one of the setup-files. It is set to mm...so maybe it's another parameter I have to change...
Sincerly
Steen
21 Oct 2015 17:04 - 21 Oct 2015 17:04 #64041 by cncbasher
can you re-email me your current files , complete folder as an archive
in fact send your old and new and i'll check
Last edit: 21 Oct 2015 17:04 by cncbasher.
The following user(s) said Thank You: Stonefire
21 Oct 2015 17:30 - 21 Oct 2015 17:32 #64044 by Stonefire
Hi CNCbasher
I'll upload the files, when I'm home from work in about 2-3 hours......
- Aspire ver 8.0..
Sincerly
Steen
Last edit: 21 Oct 2015 17:32 by Stonefire.
21 Oct 2015 19:21 #64050 by Stonefire
HI CNCbasher
Here are the files you requested...
Sincerly
Steen
21 Oct 2015 19:49 - 21 Oct 2015 20:43 #64054 by cncbasher
ok thanks , i'm back home in about 2 hours , will look at it all then , if's thats ok
find attached modified ini file , give it a try in the meantime , it should now be the same as your origional
and it is in metric .
but beware you may need to change the section
[CHANGE_POSITION]
X = 25.0
Y = 100.0
Z = 2.0
these are mm so i would say they need changing as z should be just about at top of z for toolchange
so revise as needed .. and let me know
also in tool-length-probe.ngc
change g20 to g21 and try again
Last edit: 21 Oct 2015 20:43 by cncbasher.
24 Oct 2015 17:18 #64211 by Stonefire
Hi
Are thes codes :
changing anything regarding units. My CNC is running 1/10 of the speed it use to do....
to CNCBasher: Looking into your last post during today...
Sincerly
Steen
26 Oct 2015 02:23 - 26 Oct 2015 02:24 #64260 by Stonefire
Hi again
Found the problem. The max_velocity was set to 1.00...
to: CNCBasher: It did'nt change anything. The cnc is going to 0,0 an trying to find the probe.....
Sincerly
Steen
Last edit: 26 Oct 2015 02:24 by Stonefire.
26 Oct 2015 03:17 #64261 by cncbasher
i presume you are homing the machine , it has to be something your not setting
or you think you are and not . i'll take another look just in case
26 Oct 2015 03:30 #64264 by Stonefire
Hi CNCBasher
Ok, Thanks. You got my files from last week. I have'nt change more than the Max_velocity, and added Backlatch setup...
Sincerly
Steen
Moderators: newbynobiHansU
Time to create page: 3.432 seconds
