Is someone using Gmoccapy Plasma ?
10 years 7 months ago #72246 by islander261
Thank you, I have my setup working with manual homing now. This is still a test setup with no hardware connected.
The next strange thing is also probably setup related. I am want to use imperial units (inches). In my .ini file in the [TRAG] section I have the LINEAR_UNITS = inch and in the [DISPLAY] section I have INCREMENTS = .1in .05in. .01in. ... But something still isn't right. When I jog using a step move with the resolution set to .1in the DRO shows a move of 2.540. This behavior is the same just scaled if I use another step size. It is almost as if the DRO is still counting in mm. I will be reading up on gmoccapy more today to try and find the problem but any hints are welcome.
10 years 7 months ago #72247 by islander261
Sorry I forgot to attach the needed files.
10 years 7 months ago #72253 by mariusl
When you look at the "Active Gcodes" do you see an G20 or G21?
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.069 seconds
