- Thank you received: 3
Gmoccapy INI CYCLE_TIME
- LAIR82
10 years 7 months ago #71184
by LAIR82
Gmoccapy INI CYCLE_TIME was created by LAIR82
Hello Guys,
I do not see anywhere in the gmoccapy docs the line for the CYCLE_TIME for the screen refresh rate. I know it used to be in there, but it is not mentioned now.
I have a machine that the screen gets slower and slower, and then finally freezes throughout the day.
Does this just follow the normal entry in the "INI Coniguration" section of the docs?
Rick
Rick
- Thank you received: 2181
10 years 7 months ago #71188
Replied by cmorley on topic Gmoccapy INI CYCLE_TIME
looking in the source code (2.7) gmoccapy is hardcoded at 100ms update rate.
I would start be checking the memory used during the day...maybe a memory leak.
Chris M
Chris M
- newbynobi
- Thank you received: 394
10 years 7 months ago #71286
by newbynobi
Replied by newbynobi on topic Gmoccapy INI CYCLE_TIME
Hallo Rick,
that is not normal! I know about several machines running for a hole day, without any problems.
Have you something special in your config?
What kind of machine and hardware?
Norbert
Norbert
- LAIR82
10 years 7 months ago - 10 years 7 months ago #71780
by LAIR82
Replied by LAIR82 on topic Gmoccapy INI CYCLE_TIME
Hey Norbert,
I haven't done anything really to your config, it is a bone stock Gmoccapy 2 axis lathe setup. I am running a Asrock FM2A88MM-HD+ MB, with a AMD A4020 3.4GHZ CPU, 4GB Ram and a 120GB SSD. All this is driving Mesa equipment, 5i23-7i44-7i49-7i70-7i70-7i71-7i73.
Here is a screenshot of about 5 minutes ago, the CPU load is at 85-87% running the "top" command from a remote terminal.
The control has been up since Friday the 11th, roughly 138 hours now,
Rick
Rick
Last edit: 10 years 7 months ago by LAIR82.
- newbynobi
10 years 7 months ago #71809
by newbynobi
Hallo Rick,
two questions:
- What version of gmoccapy do you use?
- How is the CPU Load after a reboot and lets say one hour of duty.
OK, I have never used my machine for 138 hours! Thats brave
Norbert
Please can someone point us in the direction how to find this hight CPU Load?
two questions:
Norbert
- LAIR82
10 years 7 months ago - 10 years 7 months ago #71825
by LAIR82
Hey Norbert,
It is running Gmoccapy V1.3.1, Linuxcnc V2.6.3
When I shut it down it was at 88%, since I restarted it, it is between 10-12%
I am just finishing up building a new SSD that has the latest version of Linuxcnc on it, 2.7.4, that I hope to drop in by Monday, see if that helps.
Rick
Rick
Moderators: newbynobi, HansU
Time to create page: 0.134 seconds
