- Thank you received: 4
gmoccapy plasma with DIY thc (KGplasma)
- kagouraki
10 years 1 month ago #80020
by kagouraki
Replied by kagouraki on topic gmoccapy plasma with DIY thc (KGplasma)
The second gladevcp user tab is ready !
I have done it by my own because the default offset widget has too many things i dont need. I took parts of the offsetcode and made my own.
You can find and test it here. Rename parameters.txt to parameters.py. Embeded in gmoccapy with
in the ini file. Place this 3 files except the sim.var in your config directory. You need to have your sim.var file in this directory too and you need to add the lines starting from 100 to 1100 like the sim.var provided. Dont replace the sim.var file unless you know what you are doing. Only edit or replace sim.var file when linuxcnc is not running.
Thank you.
EMBED_TAB_NAME = Parameters
EMBED_TAB_LOCATION = ntb_user_tabs
EMBED_TAB_COMMAND = gladevcp -x {XID} -u parameters.py parameters.glade
Thank you.
The following user(s) said Thank You: KCJ
- KCJ
- Thank you received: 267
9 years 9 months ago #85173
by KCJ
Replied by KCJ on topic gmoccapy plasma with DIY thc (KGplasma)
Hello Giorgos, very nice work!
I was planning to make a user tab for the gcode reference as well, but have not goten around to it yet. I would like to try yours but the link appears broken.
I'm off to try your parameters user tab now! Thanks for sharing.
Kurt
Kurt
- kagouraki
9 years 9 months ago #85299
by kagouraki
The embended reference is not working and i have no time to look at this so i gave it up. The parameters how ever work very well.
I hope you enjoy !
I hope you enjoy !
- KCJ
9 years 9 months ago #85301
by KCJ
OK I will have a go at making an embedded g-code reference. I will let you know if I get it to work.
Your parameters tab works great and I'm enjoining it. Thanks!
Kurt
Kurt
Moderators: newbynobi, HansU
Time to create page: 1.938 seconds
