Calling subroutine from mdi?
9 years 11 months ago #83491 by newbynobi
Replied by newbynobi on topic Calling subroutine from mdi?
Hallo Hakan,
sorry for the late reply, I am very bussy theese days.
What happen if you enter in the MDI window something like
G0 X 100 S 275 M3 G96 D2500 S250 G1 X10
Does the spindle speed change like it should?
I do not understand, why it works in Axis and not in gmoccapy, as both GUI uses the same interpreter and IMHO do handle the MDI commands in a identical way.
Norbert
9 years 11 months ago #83510 by Hakan
Replied by Hakan on topic Calling subroutine from mdi?
Yes this works as expected.
Then I wrote the commands as a subroutine and called that. Didn't work. Constant speed.
But I found out what is going on. I put in a G4 P10 after the static rpm command
to read out the rpm from the vfd - and after that the subroutine worked!?
Can it be that the spindle must be up to speed when the G96 command comes.
Why it isn't I don't know. There is a spindle-vfd.at-speed connected to motion.spindle-at-speed
in custom.hal. Perhaps that is not enough?
When I run the small command suite as a subroutine call in the MDI the speedup fails every time.
When I run it as a regular file it works every time.
When I run command by hand in MDI, the spindle speeds up as expected.
I put in a G4 P30 in the MDI and had time to enter the small command suite.
Result: Spindle didn't speedup as it should.
My assumption is the commands where then executed immediately after the G4.
So there is something with timing of commands, or many commands in a row.
Or spindle-at-speed?
Tried again with Axis - worked fine also with G4 P30.
9 years 11 months ago #83533 by newbynobi
Hallo Hakan,
I found the bug!
It is related with the spindle speed label, I found a solution, but it is only a work around.
I will push as soon as possible.
Norbert
9 years 11 months ago #83534 by newbynobi
Solved with gmoccapy 2.1.6.1,
Just pushed to master.
Solutions for 2.6 and 2.7 branch will follow soon!
Norbert
9 years 11 months ago - 9 years 10 months ago #83537 by Hakan
Yes, confirmed. Works fine now.
Thanks!
Edit: Lathemacros now works fine.
NICE!
Last edit: 9 years 10 months ago by Hakan. Reason: Addes result from test of lathemacros
Moderators: newbynobi, HansU
Time to create page: 0.520 seconds
