How to setup a 4axis gantry plasma machine using gmoccapy?
- emad
9 years 10 months ago #83551
by emad
Replied by emad on topic How to setup a 4axis gantry plasma machine using gmoccapy?
Hello again. I made a new install using the wheezy image. I installed the master branch. The current Lcnc version is 2.8.0 . Where to start, now?
- newbynobi
- Thank you received: 394
9 years 10 months ago #83564
by newbynobi
Replied by newbynobi on topic How to setup a 4axis gantry plasma machine using gmoccapy?
Just start the config:
linuxcnc-dev/configs/sim/gmoccapy/gmoccapy-JA/Gantry/gantry_mm.ini
Do not forget to start from terminal and do a rip-environment befor starting the config.
Than change the sim config to fit your needs.
Norbert
Norbert
- emad
9 years 10 months ago - 9 years 10 months ago #83587
by emad
I don't know how to start it. Can you help me with it?
Last edit: 9 years 10 months ago by emad. Reason: adding attachments
- Thank you received: 4153
9 years 10 months ago #83714
Replied by rodw on topic How to setup a 4axis gantry plasma machine using gmoccapy?
My plan is to get to gmoccapy but have started playing in axis as a starting point. I have read that is is the best for troubleshooting. It has a window you can open up to watch all of the inputs and outputs as LEDs on the screen which is very useful. So start by running stepconf and set up a system and then see if anything moves. It will create a config.
I found there is 4 things to do in Axis before you can run any gcode.
1. Turn off the estop
2. Turn on the machine
3. Home all
4. Touch Off
Then you can press start and it will run.
As I don't have limit switches in place quite yet, I had to change some of the homing settings
3. Home all
4. Touch Off
- emad
9 years 10 months ago #83715
by emad
Hi rodw. I think I have problems with master install. I'm lost here. here you are what I did:
I used Linuxcnc live Debian image. which has the 2.7 Lcnc version.
I disabled the Lcnc and Lcnc-dev from synaptic package manager.
I got the devlopment version:
git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev
cd src
./autogen.sh
./configure --with-realtime=/usr/realtime-3.4-9-rtai-686-pae
make
At this point I see the make repeats with no stops.
Can you tell me what to do, please?
cd src
./autogen.sh
make
- Thank you received: 1481
9 years 10 months ago #83716
I believe the trouble shooting tools you are referring to is Halshow and or Halmeter. Both of which are accessible in Gmoccapy, or any other Linuxcnc UI. They can actually be run separately independently of any ui in Linuxcnc (Halscope as well). They only need halrun running at a minimum.
Replied by Todd Zuercher on topic How to setup a 4axis gantry plasma machine using gmoccapy?
rodw wrote: My plan is to get to gmoccapy but have started playing in axis as a starting point. I have read that is is the best for troubleshooting. It has a window you can open up to watch all of the inputs and outputs as LEDs on the screen which is very useful.
Moderators: newbynobi, HansU
Time to create page: 0.995 seconds
