- Thank you received: 4153
How to install gmocapy?
9 years 5 months ago #93473
Correct. Took me all of 10 minutes but Gmoccappy plasma uses a few seperate HAL files so I had to tweak the INI to load them as well. Now I think it would be very difficult for me to go back to Axis as I have bound stuff so tightly to Gmoccapy python and glade files.
Replied by rodw on topic How to install gmocapy?
dewayne wrote: I take that is the display AXIS to GMOCCAPY
- dewayne
9 years 5 months ago #93477
by dewayne
Replied by dewayne on topic How to install gmocapy?
Rodw, What version of LinuxCNC and Gmocccapy are you running. As I read it seems that Gmo Ver 2.x is linked to LinuxCNC 2.8X
am I correct on this?
If I am Correct pre version 2.x of GMO can O go to 6Axis with it?
DeWayne
DeWayne
- newbynobi
- Thank you received: 394
9 years 5 months ago #93495
by newbynobi
Replied by newbynobi on topic How to install gmocapy?
gmoccapy does not support 6 axis, it is limited to 5 axis at the development state.
Norbert
Norbert
The following user(s) said Thank You: dewayne
9 years 5 months ago #93498
I'm using Master 2.8 (actually the experimental external offset branch. (dgarr/external_offsets)
dewayne wrote: Rodw, What version of LinuxCNC and Gmocccapy are you running.
DeWayne
- dewayne
9 years 5 months ago #93596
by dewayne
Rodw, What is special with the external_offsets branch. I just too the master branch..
9 years 5 months ago #93598
I don't think you will need it. It has some features for plasma cuttters so torch height adjustments can be fed in to the trajectory planner in real time as an external offset that the system does not really know about so the PID controller can work with it.
dewayne wrote: Rodw, What is special with the external_offsets branch. I just too the master branch..
Moderators: newbynobi, HansU
Time to create page: 1.298 seconds
