Should home all home the A xis?
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Oct 2017 07:19 #99902 by rodw
Should home all home the A xis? was created by rodw
Hi guys, I've just added a rotary axis to my gantry machine (YYXZA) running under 2.8.
However, the home all button does not home the the A axis.
Should it do so or is this a bug?
04 Oct 2017 14:29 #99922 by Todd Zuercher
Replied by Todd Zuercher on topic Should home all home the A xis?
What homing settings do you have for that axis (joint) in your ini file?
How do you want it to home?
If you don't want it to "do" anything, just declare the current position as home, you need to make sure that joint has these entries and settings in the ini file.
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
I think your config may be missing a few of them.
  • rodw
  • Platinum Member
  • Platinum Member
04 Oct 2017 19:37 #99934 by rodw
Replied by rodw on topic Should home all home the A xis?
Todd, Thanks, that answered my question in a roundabout way. Most appropriate for a rotary axis :)
I added your settings and now the A axis homes.
My problem was dodgy code generated by PNCCONF
Not a bug in Gmocappy.
04 Oct 2017 19:53 #99935 by Todd Zuercher
It wasn't so much dodgy code, as it was just that you had it configured for manual homing, rather than "Immediate Homing" with the "Home All" button.
  • rodw
  • Platinum Member
  • Platinum Member
04 Oct 2017 20:15 #99939 by rodw
Maybe not dodgy but I have to say PNCCONF's generated config for a slaved axis gantry was quite foreign for somebody who has only used V 2.8's superior joint axis features. :)
Moderators: newbynobi, HansU
Time to create page: 0.195 seconds
