Retaining current tool number after shutdown
- babinda01
06 Oct 2017 23:19 #100030
by babinda01
Retaining current tool number after shutdown was created by babinda01
Hi Guys
I am sure other people have encounted this problem before, but I cant find an answer. I want to be able to have the control startup with the last used tool in memory.
I have assigned variable #4999 = #5400, and then created a Remapped MCode that simply does a M71 Q#4999. This works perfectly for me except I cant get it to exercute automatically on startup.
I have added it to STARTUP_CODE under the [RS274NGC] Section. If I change the title as RS274NGC_STARTUP_CODE - Linuxcnc hangs on startup, if I leave it as STARTUP_CODE linuxcnc starts but it has no effect.
Can someone please tell me what I am doing wrong.
Best regards
Andrew
Best regards
Andrew
- newbynobi
- Thank you received: 394
09 Oct 2017 08:13 #100115
by newbynobi
Replied by newbynobi on topic Retaining current tool number after shutdown
Durring start, the axis are not homed! You are only allowed to set a tool with mdi command with homed axis!
If you use gmoccapy 2 from master, just go to the settings page and enable reload tool on start up.
After that step the tool number will be stored in your pref file and will be set with M61Qtollnumber automatically after homing the machine.
Norbert
Norbert
- babinda01
10 Oct 2017 01:30 #100130
by babinda01
Replied by babinda01 on topic Retaining current tool number after shutdown
Hi Norbert
Thanks a lot for the info. I will upgrade to master and try that.
Andrew
Andrew
Moderators: newbynobi, HansU
Time to create page: 0.070 seconds
