Gmoccapy fails to load on live CD installation
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
27 Nov 2017 14:27 #102389 by mariusl
I installed from the live CD for uspace installation. When loading Gmoccapy I get this error
Found an error!
The following information may be useful in troubleshooting:
File "/usr/bin/gmoccapy", line 102, in <module>
from gmoccapy import player # a class to handle sounds
File "/usr/lib/python2.7/dist-packages/gmoccapy/player.py", line 27, in <module>
import gst
ImportError: No module named gst
Any ideas please?
Regards
Marius
www.bluearccnc.com
  • mariusl
  • Platinum Member
  • Platinum Member
27 Nov 2017 14:31 #102390 by mariusl
27 Nov 2017 19:02 #102395 by newbynobi
Replied by newbynobi on topic Gmoccapy fails to load on live CD installation
Hallo Marius,
could you please check if python-gst- is installed?
If so, what release?
If possible install 0.10.
I do not know if the testing stretck CD does contain gmoccapy 1.XX or 2.XX, IMHO that dependency is fixed in 2.XX.
(open /usr/bin/gmoccapy with gedit and check for release number)
Norbert
  • mariusl
  • Platinum Member
  • Platinum Member
28 Nov 2017 06:47 #102423 by mariusl
Hi Norbert
Gmoccapy release is 1.5.8.
Why would they use such an old release in the latest suggested Uspace image? I feel that the sanity is slowly slipping out of Linuxcnc. It is more and more difficult to get things done if you are not a guru developer :(
There is no point in looking further to solve the problem of gst if the rest is not up to date.
Regards
Marius
www.bluearccnc.com
29 Nov 2017 15:16 #102485 by andypugh
Replied by andypugh on topic Gmoccapy fails to load on live CD installation
Hi Norbert
Why would they use such an old release in the latest suggested Uspace image?.
Because Norbert has only pushed the new stuff to Master, not to the 2.7 branch.
Updates and bugfixes put in to 2.7 will be periodically merged upstream into 2.8 / master. But nothing goes the other way (with good reason) unless the developer specifically makes that happen.
  • mariusl
  • Platinum Member
  • Platinum Member
29 Nov 2017 15:21 #102486 by mariusl
I am busy installing manual now from the documentation. It seemed to be ok before so I will see how it goes once I am done.
It might still be the easiest way
Regards
Marius
www.bluearccnc.com
  • mariusl
  • Platinum Member
  • Platinum Member
29 Nov 2017 16:40 #102492 by mariusl
If I can recommend, stay away from Debian 9 Stretch for now. It doe snot work as many dependencies are left out from the distro.
Wheezy seems to be stable. Trying that now.
Regards
Marius
www.bluearccnc.com
29 Nov 2017 21:38 #102510 by newbynobi
I am using actualy Mint 18 together with master, running fine with kernel .11 with rt-preemp patch
Just use master to get the best out of gmoccapy
Norbert
  • mariusl
  • Platinum Member
  • Platinum Member
01 Dec 2017 07:52 #102554 by mariusl
Hi Norbert
On my own machine I will do that but on a customer machine I want to use the most stable release.
I installed the Wheezy live CD and then did the RT kernel and Uspace install as per the documentation. It works great for now.
Regards
Marius
www.bluearccnc.com
Moderators: newbynobiHansU
Time to create page: 0.172 seconds
