- User Interfaces
- Gmoccapy
- slide control Max. Velocity is sporadically overwritten with zero at startup
- DerosaMH
23 Mar 2018 07:49 - 23 Mar 2018 07:51 #107745
by DerosaMH
slide control Max. Velocity is sporadically overwritten with zero at startup was created by DerosaMH
Hello
i have a problem maybe someone can help me
for me the slider is for max. Speed always 0 and can not change the machine Works flawlessly
After starting the screen 2-3 times, the controller works again until the next one
restart the screen
with G0 the maximum speed is driven
I believe that it is a problem loading the screen is working in Axis
slide regulator
Please excuse my english
restart the screen
slide regulator
Last edit: 23 Mar 2018 07:51 by DerosaMH.
- newbynobi
- Thank you received: 394
24 Mar 2018 15:15 #107780
by newbynobi
Replied by newbynobi on topic slide control Max. Velocity is sporadically overwritten with zero at startup
Hallo,
I can not see, that you have an error in your config. The behavior you discrip is not known.
What distro and what window manager do you use?
Norbert
Norbert
- DerosaMH
28 Mar 2018 05:46 #108023
by DerosaMH
Replied by DerosaMH on topic slide control Max. Velocity is sporadically overwritten with zero at startup
Hello
it is the default image of linuxcnc
I still have Virtualbox for (Windows 7), Teamviewer 12, xrdp, pcmanfm installed
otherwise I have changed nothing
Markus
Markus
Moderators: newbynobi, HansU
- User Interfaces
- Gmoccapy
Time to create page: 0.083 seconds
