Virtual keyboard?
- Ross77
19 Apr 2018 22:29 #109312
by Ross77
Virtual keyboard? was created by Ross77
Looking for pointers on installing the onscreen keyboard. Im running lcnc 2.7.12 and when I go to the settings tab in Gmoccapy the vitual keyboard settings are greyed out so dosnt seem to be installed.
Ive tryed googling it but to many options and unsure how to install on the Linux side of it. Cheers
- Thank you received: 4138
20 Apr 2018 00:42 #109322
Replied by rodw on topic Virtual keyboard?
You need to install Matchbox or Onboard keyboard separately. I could never get Matchbox working, onboard was removed from some distros for a while so it is never easy.
I think I had to add onbord to my startup options in Linux Mint.
- Ross77
20 Apr 2018 20:18 #109355
by Ross77
Replied by Ross77 on topic Virtual keyboard?
Im running Debian from the normal Lcnc live cd.
How do I install onboard? Never used Linux before so this all new to me. going around in circles google it.
20 Apr 2018 21:39 #109357
Its probably something like:
sudo apt-get install onboard
Sometimes there are version numbers etc in the name
or browse the available packages Synaptics package manager until you find it.
If you can't find it, look for matchbox instead.
- Ross77
26 Apr 2018 22:32 #109691
by Ross77
Thanks Rod
Couldn't find onboard at all, so I used Synaptics package manager to find and down load matchbox-keyboard
Installed with - sudo apt-get matchbox
Easy when you now how :oD seems to work fine in Gmoccapy, next task is to make it bigger so I can hit the button I want not the one next to it.
Thanks to Clive S as well.
Moderators: newbynobi, HansU
