Tool and work offsets
8 years 2 months ago #115831 by blazini36
Replied by blazini36 on topic Tool and work offsets
key2 wrote: Hi,
same issue here and i modfied the Change.ngc file. Documentation is on my Website (unfortunately in german). If you Need it in english, just let me now...
short description: i added an "if"-Operation checking if new tool is different to actual tool. (will upload the file later from home)
fraeserbruch.de/linuxcnc/gmoccapy-werkzeugmessung-optimiert
That's great thanks. I used Google translate and I think I have most of it but translate seems to have missed the last part, unless the German line is actually OK to use...
In detail, these changes are required in the "change.ngc" in the configuration subfolder "macros": Insert before the line ;first go up as an additional line o110 if[#<_current_tool> NE #<_selected_tool>]. NE means "Not Equal". In front of the line G43(almost at the end of the file) is called an extra lineo110 endif eingefügt
Another issue i am working on is this: if tool measurment is complete and the job is started, the spindle moves down above the TLS. i dont want this, because sometimes the TLS is higher than Z-Position in the Job =Y risk of rotating millbit crashing into TLS....
I hadn't noticed that because I've been working in my vise pretty much the whole time I've had the touchplate setup. I do have to go back to my fixture plate which is about 1" lower than the touchplate so I may have this issue as well
Moderators: newbynobi, HansU
Time to create page: 0.047 seconds
