- Thank you received: 394
For some reason if I run from line, it will execute a touchoff for every previous M6 that is in the Gcode. Is there any way around this?
[Also, the easiest way I've found to measure "block height" with the machine is to use a tool that has a Z offset in the tooltable and touch it off to the workpiece. I subtract the current absolute Z height (while the tool is toouching the workpiece) from the tooltable offset and that is the blockheight. Is there an easier way to do this rather than touching the table then touching the workpiece?
newbynobi wrote: you can change the complete behavior, just editing the change.ngc file.
Norbert
