Errors = how to solve these
- tecno
- Thank you received: 127
03 Jul 2018 18:22 #113338
by tecno
Errors = how to solve these was created by tecno
Get following errors in my mill Gmoccapy setup - those lines in BOLD what is wrong? Gtk Gdk ??
Last line must be the standard RPM progress bar as it does not function!
**** GMOCCAPY GETINIINFO ****
Preference file path: gmoccapy_preferences
**** GMOCCAPY INFO ****
**** No gmoccapy2.glade file present ****
**** Invalid embeded tab configuration ****
**** No tabs will be added! ****
**** audio available! ****
**** virtual keyboard program found : <onboard>
**** no valid probe config in INI File ****
**** disabled tool measurement ****
**** GMOCCAPY INFO: Gcode.lang found ****
(gmoccapy:4700): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failed
**** GMOCCAPY INFO : inifile = /home/bengt/linuxcnc/configs/combimill/combimillx.ini ****:
**** GMOCCAPY INFO : postgui halfile = postgui.hal ****:
(onboard:4710): Gdk-CRITICAL **: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
Emit interp-run
1 2
Emit interp-run
Something went wrong, we have an unknown spindle widget
Emit interp-run
1 2
Emit interp-run
- islander261
- Thank you received: 216
03 Jul 2018 18:41 #113340
by islander261
Replied by islander261 on topic Errors = how to solve these
Tecno
I have had the first error on my system since day one and it seems to work ok. I have no idea about the second one.
- tecno
03 Jul 2018 18:53 #113341
by tecno
Replied by tecno on topic Errors = how to solve these
It sure does appear to work OK except the RPM bar at low right = lifeless!
- newbynobi
- Thank you received: 394
03 Jul 2018 21:03 #113346
by newbynobi
Replied by newbynobi on topic Errors = how to solve these
First of all, sorry for having been away so long, but work brings money, not the hobbies?
Please post your complete config and also the complete terminal output. There must be something else wrong or misconfigured, as the unknown spindle widget line should never be reached.
Norbert
Norbert
- tecno
03 Jul 2018 21:17 #113347
by tecno
Hello Norbert,
Glad to here you are back and hopefully also OK.
Will enclose my configs tomorrow, (football......)
Can you take look at my lathe errors in earlier subject, thanks.
- tecno
04 Jul 2018 06:54 #113393
by tecno
I hope I have all necessary files included in above ZIP
mfg
Bengt
Norbert
mfg
Bengt
- newbynobi
05 Jul 2018 20:25 #113513
by newbynobi
I can not find anything strange in your hal or ini files, but there is a problem with iptables, as modprobe can not load them. I am relative shure that the unknown spindle widget error is just a later reaction to that error.
Norbert
Norbert
- tecno
05 Jul 2018 20:31 #113515
by tecno
There is no postgui with and how should this be written and where
gmoccapy.spindle_feedback_bar
gmoccapy.spindle_at_speed_led
- newbynobi
09 Jul 2018 20:09 #113888
by newbynobi
Have you solved the iptables error?
Postgui.hal, just see the example configs.
Norbert
Norbert
- tecno
09 Jul 2018 20:23 - 09 Jul 2018 20:48 #113890
by tecno
Yes IP table error is solved = has nothing to do with the errors!
have not seen any examples Norbert but I have solved that as well.
I am not so fluent on LinuxCNC but I am learning
Only those GTK GDK error are left, all apperas to work but what are those?
Last edit: 09 Jul 2018 20:48 by tecno. Reason: edit text
Moderators: newbynobi, HansU
Time to create page: 0.241 seconds
