gmoccapy no entry found in [TRAY]
- chrisfairbrother
29 Jul 2018 11:09 #115054
by chrisfairbrother
gmoccapy no entry found in [TRAY] was created by chrisfairbrother
Hi, I am testing Linuxcnc master using Gmoccappy 2.3.3.3. While resolving a slow jog velocity, I saw the following error:-
"No DEFAULT_LINEAR_VELOCITY entry found in [TRAY] of INI file
Using half on MAX_LINEAR_VELOCITY"
This is generated from /usr/share/pyshared/gmoccapy/getiniinfo.py on line 214 and two other following velocity statements.
Should these not be [TRAJ] ?
- Thank you received: 2181
29 Jul 2018 20:54 #115075
Replied by cmorley on topic gmoccapy no entry found in [TRAY]
Surely - IFIAK Gmoccapy does't add a heading called TRAY
Chris M
Chris M
30 Jul 2018 13:07 #115134
Replied by andypugh on topic gmoccapy no entry found in [TRAY]
I guess that these are just typos in the error messages.
- chrisfairbrother
30 Jul 2018 21:23 #115176
by chrisfairbrother
Replied by chrisfairbrother on topic gmoccapy no entry found in [TRAY]
Yes. They may be misleading to newer users.
30 Jul 2018 22:39 #115183
Pushed a fix - thanks for the info.
Chris M
Chris M
The following user(s) said Thank You: chrisfairbrother
Moderators: newbynobi, HansU
Time to create page: 0.222 seconds
