How To use the Over Travel signal to stop tool measurement
- silden
- Thank you received: 3
03 Sep 2018 04:11 #117003
by silden
How To use the Over Travel signal to stop tool measurement was created by silden
Hi All,
I like to use the over travel signal of my tool probe to stop the Tool measuring process and use MAXPROBE only to prevent a crash in to Z-.
Is this possible an how can I set this up?
I'm still new to GmocCapy and like to get some help with that.
Thank you all in advance,
Denis
Denis
- newbynobi
- Thank you received: 394
05 Sep 2018 05:25 #117080
by newbynobi
Replied by newbynobi on topic How To use the Over Travel signal to stop tool measurement
You can connect the over travel signal to the estop signal.
This is not gmoccapy related, it is just a hal matter.
Regards Norbert
Regards Norbert
- silden
05 Sep 2018 05:29 #117081
by silden
Replied by silden on topic How To use the Over Travel signal to stop tool measurement
You are right that I can connect it to the e-stop, this is what I already do.
I wanted to only abort the probing cycle and not stop the whole machine. Similar to the MAXPROBE implementation.
Thanks,
Denis
Thanks,
Denis
07 Sep 2018 15:32 #117190
Replied by andypugh on topic How To use the Over Travel signal to stop tool measurement
Try halui.abort
linuxcnc.org/docs/2.7/html/man/man1/halui.1.html
Moderators: newbynobi, HansU
Time to create page: 0.087 seconds
