Gmoccapy edit interface
- Thank you received: 2181
03 Jan 2021 01:12 #193906
Replied by cmorley on topic Gmoccapy edit interface
try adding actions with a right click 'add to top level' that seems to work.
- HansU
- Thank you received: 217
03 Jan 2021 19:40 - 03 Jan 2021 19:41 #193978
by HansU
In a rip environment I got it started with 3.8.6. Thanks for that hint. Even with Glade 3.8.0 is it possible if I start it in a rip environment.
Replied by HansU on topic Gmoccapy edit interface
I am not able to reproduce this.
It is known, that the glade Editor is buggy. I have compiled mine from source! It is necessary to use glade 3.8.6 editor. Please check if you use that release. And it might be necessary to start the editor from a rip-environment terminal.
Norbert
Last edit: 03 Jan 2021 19:41 by HansU.
Moderators: newbynobi, HansU
Time to create page: 0.471 seconds
