How to get M-Code Status in HAL
- sevaz
- Thank you received: 5
21 Nov 2018 20:28 #121171
by sevaz
How to get M-Code Status in HAL was created by sevaz
Hello! I really want to know is there any way to get the status of modal commands, like M5, G21, G40,M9 and so forth. I would like to replace Gcode panel with LED one, which would show only necessary parameters. Is it possible?
- Thank you received: 2181
21 Nov 2018 22:23 #121181
Replied by cmorley on topic How to get M-Code Status in HAL
Yes and no.
You can use python to read the M and g codes and use that data for what ever you want. GladeVCP would be a good choice for this.
But unfortunately it reads the state of the interpreter which can be far ahead of the actual running gcode.
There has been effort to fix this problem (a branch called state-tags) but it is relatively far away from being incorporated.
Chris M
Chris M
The following user(s) said Thank You: sevaz
- Thank you received: 1480
21 Nov 2018 22:58 #121185
Replied by Todd Zuercher on topic How to get M-Code Status in HAL
In other words yes there is supposed to be a way, but no you can't really use it for anything useful because it is currently broken (and has been since the introduction of the new tool planner.)
21 Nov 2018 23:05 #121186
actually the new trajectory planer didn't break this, it always been this way.
Chris M
Chris M
22 Nov 2018 18:15 #121227
With the old planner I thought it was only 1 line ahead rather than all the way to the end.
- Thank you received: 4152
22 Nov 2018 19:43 #121230
I know I shouldn't complain as we are all volunteers but I find it frustrating when valuable branches like this and reverse run seem to get right through ready to be merged into master branch but then languish in limbo for such a long time (sometimes 3 years or more) that the code base moves so far ahead of them they become broken and its a major work to merge them. The original author is not likely to be motivated to redo his work after his first experience.
Replied by rodw on topic How to get M-Code Status in HAL
22 Nov 2018 21:58 #121238
yes that is true. but either way the interpreter makes a large list of commands it has pre-planned - faster then the machine can run them usually.
Trajectory planning look-head describes the amount of lines ahead (usually ahead of the currently running line) it considers when planning. It improves quality of movement of course.
The Interpreter list is just a place for the planner to keep those pre-planned moves.
Chris M
Chris M
22 Nov 2018 22:04 #121239
Yes it's an on going problem (and a underlying reason why machinekit was forked).
I believe it's a combination of things (my off the cuff opinion):
because of a lack of people to do merging.
The maybe-too-restrictive of keeping master basically usable as production on a machine at all times.
Not pushing master out more regularly.
Which really comes down to the first reason
Chris M
Chris M
- newbynobi
- Thank you received: 394
22 Nov 2018 22:41 #121241
by newbynobi
Replied by newbynobi on topic How to get M-Code Status in HAL
Sorry Guys,
but you are getting off topic! The merge etc does not belong to gmoccapy!!
But you are right and wrong! If you are interested in thre merge of a branch, test it!!! And report about the results, so it will be merged! Do not shout on developers if you do not participate.
You are right in the meaning of master, Imho we shouild have three main branches, stable, master and development.
Pardon for the open words.
Norbert
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.101 seconds
