Gmoccapy not starting in maximized
  • Nitram
  • Nitram's Avatar Topic Author
  • Elite Member
  • Elite Member
18 Feb 2019 00:49 - 19 Feb 2019 02:16 #126699 by Nitram
Gmoccapy not starting in maximized was created by Nitram
Hello.
Even though I have the gmoccapy settings set to start as a full screen, on startup the screen is always smaller than full screen.
I have to maximize it in order for it to cover the full screen with each start.
I have not had this problem with other computers running linuxcnc.
This is on a Lenovo Thinkpad.
Thanks for any guidance.
Cheers,
Marty.
Last edit: 19 Feb 2019 02:16 by Nitram. Reason: Change of thread title
18 Feb 2019 05:43 - 18 Feb 2019 05:44 #126709 by newbynobi
Replied by newbynobi on topic Gmoccapy not starting in full screen
Have you tried to delete the preference file in your config dir?
I know of one case, that an entry has not been taken in account after a copy the config to the new computer using a windows file system.
Norbert
Last edit: 18 Feb 2019 05:44 by newbynobi.
  • Nitram
  • Elite Member
  • Elite Member
18 Feb 2019 13:25 - 19 Feb 2019 02:15 #126714 by Nitram
Replied by Nitram on topic Gmoccapy not starting in full screen
Thanks Norbert.
I will check the pref file tomorrow and see whether it has the correct setting. If not I will change it there.
I believe the parameter is screen1 or display1, something like that?
Can you tell me the possible settings for this parameter?
I guess it would be "window, fullscreen or maximized"?
Do I have the syntax right?
Marty.
Last edit: 19 Feb 2019 02:15 by Nitram.
  • Nitram
  • Elite Member
  • Elite Member
19 Feb 2019 02:13 - 19 Feb 2019 02:18 #126745 by Nitram
Replied by Nitram on topic Gmoccapy not starting in maximized
HI Norbert.
I have checked the pref file. It shows maximized.
When I change it to fullscreen, the display changes to fullscreen. But when in maximized, it only opens as a window each time. I have deleted the pref folder and reopened gmocchapy so that it would create a new pref folder, but the behavior is the same.
Interestingly, once gmoccapy is open I CAN push the maximize window icon in the top right of the screen and it does that correctly, just not as a pre-set from within gmoccapy to do it automatically...
The pref file pixel size is 979x768. I have tried changing the width larger, but the window size does not change.
Do you have any other suggestions to try??
Many thanks,
Marty.
Last edit: 19 Feb 2019 02:18 by Nitram.
19 Feb 2019 09:31 #126759 by cmorley
Replied by cmorley on topic Gmoccapy not starting in maximized
what version of linux are you using? I wonder if it's a window manager problem.
Chris
19 Feb 2019 21:35 #126789 by newbynobi
Replied by newbynobi on topic Gmoccapy not starting in maximized
Yes, i need details about the OS , window manager and gmoccapy release to try to simulate the problem here.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.096 seconds
