is-paused not accurate
19 Feb 2019 04:54 #126750 by thadwald
is-paused not accurate was created by thadwald
I'm not sure if this is a gmoccapy topic but I am using gmoccapy and so here we go:
When the program is started, then paused, the halui.program.is-paused accurately reflects the state of the machine while single-stepping throught the g-code. However, when the program is stepped into using the step-by-step button, the halui.program.is-paused turns off after several steps, and halui.program.is-running turns on.
I presume this to be a bug?
19 Feb 2019 09:39 #126761 by cmorley
Replied by cmorley on topic is-paused not accurate
What version of linuxcnc are you using? I tried it with a master version with a simulated config and it seemed to work fine.
Chris
19 Feb 2019 13:37 #126769 by thadwald
Replied by thadwald on topic is-paused not accurate
I am using version 2.8. I just compiled from source and it still behaves as I described.
19 Feb 2019 15:32 #126772 by joekline9
Replied by joekline9 on topic is-paused not accurate
I have the same issue with 2.7.x using Axis. I have to hit Stop then resume.
19 Feb 2019 21:31 #126788 by newbynobi
Replied by newbynobi on topic is-paused not accurate
Are you using halui pin to step, or the gmoccapy button?
Norbert
21 Feb 2019 17:23 #126864 by thadwald
I am using the halui pin. The gmoccapy pause button works to resume the program every time. However, the gmoccapy step button has the same effect as the halui.program.step pin; when the program is initiated with step, the haul.program.is-paused and halui.program.is-running pins don't correctly reflect the machine state.
Moderators: newbynobi, HansU
Time to create page: 0.181 seconds
