File not visible
- Mike_Eitel
- Thank you received: 183
09 Mar 2019 12:44 #128157
by Mike_Eitel
File not visible was created by Mike_Eitel
Hi
I have a strange effect. I do have copied a file from usb stick in a nc_files subdirectory.
And unplugged the stick. This directory is not empty and all files have .ngc extention.
Owner is my user.
In Gmoccappy I try to load that file. But I can not see it. All other files are visible. Just made a copy... Not visible neither????
I generated the file like many others with Mastercam and tranferde via USB stick.
Any idea.
THX in advance.
MIKE
Owner is my user.
Any idea.
THX in advance.
MIKE
- Mike_Eitel
09 Mar 2019 14:34 #128165
by Mike_Eitel
Replied by Mike_Eitel on topic File not visible
I tried with short filename and also an empty file with. ngc extention.
All files are shown a Gcode files in explorer.
All permissions and the owner in the directory and level up are the same.
- newbynobi
- Thank you received: 394
11 Mar 2019 17:36 #128358
by newbynobi
Replied by newbynobi on topic File not visible
My experience is that that doe happen if there are unknow letters in the file.
Please post the file, so I can check that out.
Norbert
Norbert
- Mike_Eitel
11 Mar 2019 17:50 #128361
by Mike_Eitel
Thx Norbert.
But I did a simple copy of a file in the directory, and did not see that neither... I wiil need some days until I have time to touch my system. Will keep you informed when I have found.
Mike
Mike
- Grotius
- Thank you received: 2349
11 Mar 2019 22:29 - 11 Mar 2019 22:30 #128391
by Grotius
Replied by Grotius on topic File not visible
Mike,
If you use a good ssd disk this problem is problably gone. I had that problem before with poor usb sticks.
www.wd.com/nl-nl/products/portable-storage.html
I use the passport ssd. Perfect for me. Works always on linux. You can smash it to the ground and it works again.
Last edit: 11 Mar 2019 22:30 by Grotius.
- Mike_Eitel
12 Mar 2019 05:39 #128414
by Mike_Eitel
This is as fare as I see not a bad sdd
Ordered for more businesses like use in Raspberry but works also nice in my CNC pc.
www.aliexpress.com/item/KingDian-Hot-Ite...2-5/32830117504.html
- newbynobi
12 Mar 2019 17:17 #128454
by newbynobi
I am sure the SSD is not the problem, as he can see the other files. Most common are strange names, may be even with a leading dot or such stuff.
- Mike_Eitel
12 Mar 2019 19:02 - 12 Mar 2019 20:20 #128465
by Mike_Eitel
Noop
It was user stupidity!!!!
I believed that I set a link on desktop to my ngc files directory. BUT
It was a copy, based/connected on the desktop.
Took me hours, and only a file search of complete disk with midnight commander let me find that. Grrrrrrr
Mike
Mike
Last edit: 12 Mar 2019 20:20 by Mike_Eitel.
Moderators: newbynobi, HansU
Time to create page: 0.411 seconds
