Is gmoccapy included in Release 2,7,14?
02 May 2019 16:09 #132544 by Buddy002
Is gmoccapy included in Release 2,7,14? was created by Buddy002
I loked on the iso file and found no indication that it is there.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
02 May 2019 17:30 - 02 May 2019 17:33 #132549 by Todd Zuercher
Replied by Todd Zuercher on topic Is gmoccapy included in Release 2,7,14?
Gmoccapy is included with Linuxcnc version 2.7.14 (I think it is version 1.5)
Newer versions of Gmoccapy are restricted to 2.8-pre and newer versions because maintaining the differences between the newer JA versions of Linuxcnc and 2.7 was not worth the effort.
PS: the Wheezy ISO does not have 2.7.14 it is 2.7.0. You must update after installing to get 2.7.14. (Not sure about the Stretch Preemt-RT ISOs they are likely more uptodate.)
Last edit: 02 May 2019 17:33 by Todd Zuercher.
05 May 2019 12:35 #132831 by Buddy002
Replied by Buddy002 on topic Is gmoccapy included in Release 2,7,14?
Thanks for your reply, so if I want to use gmoccapy I will need to down load an older version of linuc an then update to 2.7.14
05 May 2019 13:11 #132832 by rodw
Replied by rodw on topic Is gmoccapy included in Release 2,7,14?
No need to do that. Its included in V 2.7 but latest changes are only in V2.8. I would not think that is a limitation as if there was a major bug, I'm sure it would be fixed in 2.7
There are some fairly significant changes to Linuxcnc in 2.8 so I would not expect you could use the latest version in v 2.7. YO need to upgrade to V 2.8 instead.
07 May 2019 14:32 #133054 by Buddy002
I will give this a try
Moderators: newbynobi, HansU
Time to create page: 0.167 seconds
