hal und postgui.hal Timing with extra Panel
- MatthiasF1210
27 May 2019 20:29 #135088
by MatthiasF1210
hal und postgui.hal Timing with extra Panel was created by MatthiasF1210
I have a strange behavior with my newly programmed panel.
My panel is a glade panel with a dedicated python panel. Inside the python file are some pins defined:
After starting halscope the pins are visible.
With my postgui halfile the pins are connected as followed:
In my virtual machine linuxcnc is running fine with the panel without errors. If I move the config to my real machine it is not working, with the following error:
So i think there is a different timing on my real machine!
What can I do to be sure that all the python halcomp's are ready before the postgui.hal is loaded?
Matthias
# Hal Pins Anlegen
self.halcomp = hal.component("serviceCon")
self.halcomp.newpin( "spindle_TS", hal.HAL_S32, hal.HAL_IN)
self.halcomp.newpin( "runTimeOA_TS", hal.HAL_S32, hal.HAL_IN)
self.halcomp.newpin( "totalWayOfTravel", hal.HAL_FLOAT, hal.HAL_IN)After starting halscope the pins are visible.
net saveRT_TS => serviceCon.runTimeOA_TS
net saveST_TS => serviceCon.spindle_TS
net twoTravel => serviceCon.totalWayOfTravelIn my virtual machine linuxcnc is running fine with the panel without errors. If I move the config to my real machine it is not working, with the following error:
PIN: 'serviceCon.runTimeOA_TS' does not existSo i think there is a different timing on my real machine!
Matthias
- Thank you received: 2181
28 May 2019 03:27 #135112
Replied by cmorley on topic hal und postgui.hal Timing with extra Panel
please post your config files.
- newbynobi
- Thank you received: 394
28 May 2019 04:46 #135119
by newbynobi
Replied by newbynobi on topic hal und postgui.hal Timing with extra Panel
No need to post your files, as that is a known behavior.
Timing is as follows:
LinuxCNC hal files as per your ini
Postgui.hal
Glade panel
So you need to do the named connections in a separate hal file, witch you load together with the panel . use parameter -H for that purpose within the load line in your ini file.
Norbert
Postgui.hal
Glade panel
Norbert
- MatthiasF1210
28 May 2019 20:30 #135191
by MatthiasF1210
Replied by MatthiasF1210 on topic hal und postgui.hal Timing with extra Panel
Hi Norbert,
Life can be so easy
Thanks a lot Works perfect
Matthias
Life can be so easy
Matthias
Moderators: newbynobi, HansU
Time to create page: 0.411 seconds
