Gmocappy wont load with new RIP install
7 years 4 months ago #136395 by bevins
I dont know what I did wrong but everything loads except gmocappy. I did plasmac, linuxcnc-dev tried all sorts. gmocappy wont load.
I must have messed up gtk.
Starting LinuxCNC... Found file(lib): /home/denis/linuxcnc-dev/lib/hallib/core_sim.hal Note: Using POSIX non-realtime Found file(REL): ./spindle_sim.hal Found file(lib): /home/denis/linuxcnc-dev/lib/hallib/simulated_home.hal Traceback (most recent call last): File "/home/denis/linuxcnc-dev/bin/gmoccapy", line 36, in <module> import gladevcp.makepins # needed for the dialog"s calculator widget File "/home/denis/linuxcnc-dev/lib/python/gladevcp/__init__.py", line 1, in <module> from hal_pythonplugin import * File "/home/denis/linuxcnc-dev/lib/python/gladevcp/hal_pythonplugin.py", line 30, in <module> from hal_gremlin import HAL_Gremlin File "/home/denis/linuxcnc-dev/lib/python/gladevcp/hal_gremlin.py", line 32, in <module> import gremlin File "/home/denis/linuxcnc-dev/lib/python/gremlin.py", line 40, in <module> import gtk.gtkgl.widget ImportError: No module named gtkgl.widget Shutting down and cleaning up LinuxCNC... task: 24 cycles, min=0.000008, max=0.001082, avg=0.000906, 0 latency excursions (> 10x expected cycle time of 0.001000s) Note: Using POSIX non-realtime LinuxCNC terminated with an error. You can find more information in the log: /home/denis/linuxcnc_debug.txt and /home/denis/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal denis@plasma01:~/linuxcnc-dev$
7 years 4 months ago #136398 by bevins
My bad.... Found some missing dependencies. now all loads fine
6 years 8 months ago #158149 by harvey
Hi
I have the same problem, Which dependencies were missing ?
6 years 8 months ago #158200 by ikkuh
harvey wrote: Hi
This is not a clue?
6 years 8 months ago #158203 by harvey
It's a clue, but I can't interpret it. I don't know how to fix the bug
  • BeagleBrainz
  • New Member
  • New Member
6 years 8 months ago #158206 by BeagleBrainz
Moderators: newbynobi, HansU
