Tool related pin, Pin does not exist
  • macsddau@linuxcnc
  • macsddau@linuxcnc's Avatar Topic Author
  • Premium Member
  • Premium Member
23 Oct 2019 14:43 - 23 Oct 2019 14:45 #148601 by macsddau@linuxcnc
Tool related pin, Pin does not exist was created by macsddau@linuxcnc
I'm following this manual page :
linuxcnc.org/docs/2.7/html/gui/gmoccapy.html#_tool_related_pin
In .ini.hal file I made this modification (gmoccapy lines are copy/paste form documentation) :
#net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
#net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
#net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
#net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
net tool-prep-number gmoccapy.toolchange-number <= iocontrol.0.tool-prep-number
net tool-prep-loop iocontrol.0.tool-prepare <= iocontrol.0.tool-prepared
Finally I get this error :
Pin 'gmoccapy.toolchange-change' does not exist
What's wrong in my inihal file and/or the documentation ?
Last edit: 23 Oct 2019 14:45 by macsddau@linuxcnc.
23 Oct 2019 15:51 #148604 by pl7i92
Replied by pl7i92 on topic Tool related pin, Pin does not exist
try to do this in a postgui FILE so all is loaded at the time you interact with the gui
The following user(s) said Thank You: macsddau@linuxcnc
  • macsddau@linuxcnc
  • Premium Member
  • Premium Member
23 Oct 2019 16:04 #148607 by macsddau@linuxcnc
Replied by macsddau@linuxcnc on topic Tool related pin, Pin does not exist
Did I have to keep
in the hal file ?
  • macsddau@linuxcnc
  • Premium Member
  • Premium Member
23 Oct 2019 16:34 #148610 by macsddau@linuxcnc
Thanks pl7i92. This is the solution !
I haven't keep the loadurs in hal file.
23 Oct 2019 17:15 #148612 by newbynobi
Replied by newbynobi on topic Tool related pin, Pin does not exist
Hallo,
you do not need the line:
Just comment it out.
Norbert
Moderators: newbynobi, HansU
