gmoccapy freeze at toolchange
- billykid
- Thank you received: 83
05 Nov 2019 11:56 #149629
by billykid
gmoccapy freeze at toolchange was created by billykid
Hello,
I have a configuration with tool change and probe used to drill some printed circuits perfectly.
after installing nativecam and campy both working I realized that the "insert tool .... and click ok" window remains locked. the program continues to do the same but cannot be stopped.
use debian stretch with linuxcnc 2.7.14.
Thanks in advance
mauro
Thanks in advance
mauro
- newbynobi
- Thank you received: 394
05 Nov 2019 15:17 #149654
by newbynobi
Replied by newbynobi on topic gmoccapy freeze at toolchange
Please disable probe and try again. If that does work, it is a probe problem, otherwise post your config, as it will be a config prble, most probaly wkth toll change and tool changed hal pin
Norbert
Norbert
- billykid
06 Nov 2019 04:10 - 06 Nov 2019 04:39 #149682
by billykid
Replied by billykid on topic gmoccapy freeze at toolchange
Thanks Norbert,
I tried to disable the probe but it blocks the same .. I only added Campy non nativecam I was wrong to write, the one on another configuration with axis. Gmoccapy before campy first went perfectly.
I attach the ini file, if you need more, tell me.
thanks
Mauro
thanks
Mauro
Last edit: 06 Nov 2019 04:39 by billykid.
- billykid
07 Nov 2019 05:34 #149835
by billykid
practically the tool change and the probe work, only the dialogue window "please insert tool...." remains frozen, but the machine continues to work regularly but no command answers any more and the forced closing of the window completely closes linuxcnc
- newbynobi
08 Nov 2019 08:49 #149920
by newbynobi
Is this a auto toolchange, or a manual one?
What happen if you enter in MDI mode a toolchange comand like
T3 M6
Norbert
T3 M6
Norbert
- billykid
08 Nov 2019 09:30 #149923
by billykid
m6t2 works perfectly. the dialog box remains locked, this after installing nativecam. now I am reinstalling everything clean also because I want to use wheezy even if old at 8 khz is better than stretch.
the stretch installation works perfectly but for the 5i23 I think the old kernel is better since it also has better latency.
thanks also for the good work
Mauro
Mauro
- billykid
10 Nov 2019 12:52 - 10 Nov 2019 12:59 #150074
by billykid
I reinstalled everything and it was not nativecam as I thought .. the error occurs after installing Campy
Last edit: 10 Nov 2019 12:59 by billykid.
- billykid
11 Nov 2019 06:30 - 11 Nov 2019 09:33 #150104
by billykid
Hello
I have other info, practically enough that it goes in the setting ----> advanced setting
> launch text message to get the usual block. it confirms to me that it is the message that blocks everything. not the tool change that works perfectly. this after installing
and this problem is the same
campy.www.forum.linuxcnc.org/gmoccapy/34855-ca...occapy-2-7-14#113883
Last edit: 11 Nov 2019 09:33 by billykid.
- Philippe
11 Dec 2019 01:41 #152472
by Philippe
Replied by Philippe on topic gmoccapy freeze at toolchange
Hello all,
I've the same problem with the automatic tools change, my cnc go to the good position to change the tool and the program freeze there is no popup that appear.
i've the same configuration in the differents files than you .
what's append ?
what's append ?
- billykid
11 Dec 2019 14:38 #152492
by billykid
I don't know what to say ... I reinstalled everything several times and it worked out in the end, but I don't know what the problem was.
Mauro
Mauro
Moderators: newbynobi, HansU
