GUI for camshaft grinder
- kayaba
- Thank you received: 3
24 Dec 2019 14:26 #153167
by kayaba
GUI for camshaft grinder was created by kayaba
Hi ppl in forum,im newbie here,i was succes instal linux in my router,
And now ihave challenge,my dad have grinding camshaft,he need me to rettofit using linux,
He want like it
Thnk you
He want like it
Thnk you
- kayaba
24 Dec 2019 14:30 #153169
by kayaba
Replied by kayaba on topic GUI for camshaft grinder
Another video
I dont find comercial until hobby making this controller,so i think will hot if linuxcnc can be porting like that
Tnk you
Tnk you
- Leon82
- Thank you received: 79
24 Dec 2019 15:21 #153170
by Leon82
Replied by Leon82 on topic GUI for camshaft grinder
I don't see why you couldn't as long as you can generate the correct gcode. Encoders are probably a good to guarantee timing consistency
- kayaba
24 Dec 2019 23:28 #153183
by kayaba
Yes,ithink is same idea what iam thinking,
So best process is,touch probe with x axis(wheel) with A axis going turn a.k.a 5 degree,then save coordinat with dxf format,
Then user can be redraw,
Then gcode produce
Then gcode produce
- Leon82
25 Dec 2019 00:05 #153184
by Leon82
You could most likely use a probe to digitize a cam profile
Then gcode produce
- kayaba
25 Dec 2019 00:30 #153185
by kayaba
Yes,any thread to read ?for point cloud in linux?
- newbynobi
- Thank you received: 394
26 Dec 2019 07:20 #153233
by newbynobi
Replied by newbynobi on topic GUI for camshaft grinder
Take a look in the sim nc_files at gridprobe.ngc
That file does generate a probe file, what can be used in other programs.
At younger tuning times, I used a digital dial (0,001 mm resolution) and steel disk with a 360 degree marks on it.
I transferred every degree a value of the dial to an excel sheet. I used that data do make a master hub and a copy grinding machine to produce the cam shafts for ma motorcycles
Norbert
Norbert
- kayaba
01 Jan 2020 18:24 #153756
by kayaba
Yes,it can be realized,but need more long time to generate code.
How about all going to automate process,if its can This way will much better
07 Jan 2020 16:48 - 07 Jan 2020 16:49 #154274
Replied by andypugh on topic GUI for camshaft grinder
Cam grinding is complicated by the fact that the contact point moves up and down as the cam rotates due to tangent angles. So the wheel diameter is a critical variable. And that changes as the process continues.
So I think that a cam grinder needs some form of wheel diameter measurement to work properly.
I did have a bit of a play around some time ago.
Last edit: 07 Jan 2020 16:49 by andypugh.
The following user(s) said Thank You: kayaba
- kayaba
12 Jan 2020 23:01 #154738
by kayaba
Hi dear friand,i just open pdf doc was i download,
Mybe its can be porting into linuxcnc
www.qproducts.sk/files/04_Motion_Control.pdf
Moderators: newbynobi, HansU
Time to create page: 0.300 seconds
