Problem with hal pins (solved)
- Gaunt1969
- Thank you received: 8
01 Feb 2020 22:21 - 01 Feb 2020 23:24 #156326
by Gaunt1969
Problem with hal pins (solved) was created by Gaunt1969
In the new version , did the hal pins change for the spindle? And if so what are they?
Last edit: 01 Feb 2020 23:24 by Gaunt1969.
- Thank you received: 7488
01 Feb 2020 23:38 #156328
Replied by tommylight on topic Problem with hal pins (solved)
Where is the problem ? And why did you title it as "solved", where is the solution ?
That is very misleading, and confusing for other users.
The 2.8 and 2.9 version use spindle.0. in the hal files as they do support multi spindle setups.
- Gaunt1969
02 Feb 2020 13:08 #156372
by Gaunt1969
Replied by Gaunt1969 on topic Problem with hal pins (solved)
Sorry about that spindle.0. Is the solution I thought I had posted it.
02 Feb 2020 17:31 #156390
Thank you.
- ajsinfotech
13 Apr 2020 12:29 - 13 Apr 2020 12:36 #163872
by ajsinfotech
Replied by ajsinfotech on topic Problem with hal pins (solved)
Hi
I am building on a RPi3 + Mesa7c81 + Debian Buster platform. I decided to use GMOCCAPY because I had some problems configuring Qt environment.
So about GMOCCAPY, why I can not see any GMOCCAPY pin/object in halshow?
What is missing?
What is missing?
Last edit: 13 Apr 2020 12:36 by ajsinfotech.
- newbynobi
- Thank you received: 394
16 Apr 2020 21:01 #164202
by newbynobi
Replied by newbynobi on topic Problem with hal pins (solved)
If gmoccapy is running the pins should be vissible
Norbert
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.489 seconds
