Hi can't switch to automode and other errors
- harvey
15 Feb 2020 07:11 #157434
by harvey
can't switch to automode and other errors was created by harvey
Hi
My system : Debian with rt-kernel 4.9.0-12
Gmoccapy: 3.0.8.2
Linuxcnc: 2.9.0-pre0-1036-g7839e0ba1
I have a functional system with AXIS as userInterface. I had configured it with stepconf.
No I tried gmoccocapy as user-interface.
I made a config with stepconf.
I am able o jog around on x, y, z axis. I can turn my spindel on and of and change the pwm.
Not working is homing; the x-axis went into the wrong direction (with Axis as User-interface it works).
I can't change to automode or MDI-mode. Both buttons are greyed-out.
Gmoccapy: 3.0.8.2
- Clive S
- Thank you received: 486
15 Feb 2020 07:28 #157435
by Clive S
change the sign on HOME_SEARCH_VEL = -10.000000 ie. if it is -ve delete the -
Replied by Clive S on topic can't switch to automode and other errors
- harvey
15 Feb 2020 09:52 #157457
by harvey
Replied by harvey on topic can't switch to automode and other errors
Hi
Thanks for the quick response. But now i have much more trouble. Every homing in AXIS and Gemoccapy works only one time. After that the mill go in the wrong direction. First i have to configure my mill that it is works in AXIS again. After that I will try your settings.
I think I should take an older version of linuxcnc.
- Clive S
15 Feb 2020 10:13 #157459
by Clive S
post your ini and hal files
Hi
The following user(s) said Thank You: harvey
- harvey
15 Feb 2020 10:33 #157463
by harvey
Replied by harvey on topic Hican't switch to automode and other errors
Hi
Too late. I make an fresh install with linuxcnc 2.7. After this I make a parallel installation of Linuxcnc2.9 again for testing.
But this will last a moment because my wife want to spend time with me too.
I will test it next week.
- harvey
17 Feb 2020 07:01 #157597
by harvey
Replied by harvey on topic Hi can't switch to automode and other errors
Hi
After reinstalling linuxcnc2.9 I've got now a working gmoccapy configuration.
Now i will make some tests.
Moderators: newbynobi, HansU
Time to create page: 0.162 seconds
