LINEAR POTENTIOMETERS
- Thank you received: 2181
27 Feb 2020 20:48 #158688
Looking here I see you are using direct value but counts is hard coded to 1.
counts is how you adjust the rate.
counts * scale = SO percentage
You also seem to have a second scale component - halui.spindle.0.oveeride has it's own scale setting
Chris
Replied by cmorley on topic LINEAR POTENTIOMETERS
#---SPINDLE-OVERRIDE-POT---START---
net spindle-analogue hm2_7i92.0.7i77.0.0.analogin1 => spindle-scale.in
net spindle-override spindle-scale.out halui.spindle.0.override.scale
setp halui.spindle.0.override.counts 1
setp halui.spindle.0.override.direct-value 1
setp spindle-scale.gain 4.18
#===POT INPUT IS LINEAR 0-23.915v===
setp spindle-scale.offset 0
#---SPINDLE-OVERRIDE-POT---END---
#============================================================Looking here I see you are using direct value but counts is hard coded to 1.
Chris
The following user(s) said Thank You: COlger81
27 Feb 2020 20:52 #158690
You can connect pins anywhere you like provided they are available.
postgui file was made because gui pins tend to come late into the process.
Following convention makes it easier for others to follow - but it's not required.
Chris
hi there is a HALUI section in the ini and also inside the POSTgui HAL
your in i loads up a Coustom_postgui file that is inside the machine fiolder
THERE you need to connect to a halui pin NOT IN THE MAIN HAL
see here the pinnames for spindle override
linuxcnc.org/docs/html/man/man1/halui.1.html
Chris
- COlger81
- Thank you received: 6
27 Feb 2020 21:04 #158691
by COlger81
Replied by COlger81 on topic LINEAR POTENTIOMETERS
Thanks Chris, i got it sorted and working. I understand the flow now and the need for postgui.
- COlger81
27 Feb 2020 21:05 #158692
by COlger81
I ended up using the Gmoccapy override pins.
Moderators: newbynobi, HansU
Time to create page: 0.626 seconds
