changing modes
- blazedforever
27 Feb 2020 12:05 #158656
by blazedforever
changing modes was created by blazedforever
so i have some buttons on my custom screen that run mdi commands when pressed, then it stays in mdi mode. How can i switch it back to manual or auto after the movement so the jog buttons will work again.
- Thank you received: 7504
27 Feb 2020 12:23 #158661
Replied by tommylight on topic changing modes
I am pretty sure this was asked before, but am on the phone so can not help much.
Try to search google but add
Site:linuxcnc.org
After the search terms.
Site:linuxcnc.org
- COlger81
- Thank you received: 6
27 Feb 2020 12:58 #158672
by COlger81
Replied by COlger81 on topic changing modes
Post your files and i can help you sort it out.
- blazedforever
27 Feb 2020 13:09 #158677
by blazedforever
Replied by blazedforever on topic changing modes
i've tried some searches on google and on here , cant seem to find a working answer. the closest i've got is adding this code to the handler file and calling it right after the mdi movement
self.command.mode( linuxcnc.MODE_MANUAL )
self.command.wait_complete()
but i just get tracebacks saying command is not valid
- COlger81
27 Feb 2020 13:13 #158680
by COlger81
Files?
27 Feb 2020 13:49 #158685
See if this helps:
www.google.com/search?sxsrf=ALeKk00q1BPh...raAK4Q4dUDCAo&uact=5
- blazedforever
27 Feb 2020 13:54 #158686
by blazedforever
not sure what files you want but heres the handler file and the error im getting when trying the above method found searching this forum
- Thank you received: 2181
27 Feb 2020 17:34 #158697
Replied by cmorley on topic changing modes
Change this:
To This:
an alternative:
The code looks weird because gscreen has the reference to linuxcnc command a couple layers deep.
If you import linuxcnc in the handler file, you could use the more familiar coding.
Chris
def on_mdi_command_finished(self, data=None):
self.command.wait_complete() To This:
self.emc.set_manual_mode()an alternative:
self.emc.emccommand.mode(self.emc.emc.MODE_MANUAL)
self.emc.emccommand.wait_complete() If you import linuxcnc in the handler file, you could use the more familiar coding.
Chris
27 Feb 2020 17:42 #158700
Also to facilitate faster help this info is helpful as a start:
What version of linuxcnc
What Screen or screen building toolkit you are using.
What you expected to happen
What actually happened.
An exact description of the error message.
the relevant config files - usually easiest to zip up all of them and post that - unless you are very sure where the error lies.
In this case the error message and the handler file was all the info that was needed,
gscreen takes some time to get the hang of and it is a little hard to follow where the answers are.
In the future QtVCP is an improvement.
Chris
Chris
The following user(s) said Thank You: blazedforever
27 Feb 2020 17:50 #158702
If you are wondering where I got this:
You can look here for other functions
github.com/LinuxCNC/linuxcnc/blob/2.7/sr...een/emc_interface.py
Chris
self.emc.set_manual_mode()You can look here for other functions
Chris
Moderators: newbynobi, HansU
Time to create page: 0.143 seconds
