Back tool lathe mode not working
01 Jun 2020 21:45 #169724 by Schaap
Back tool lathe mode not working was created by Schaap
Hello,
I’m trying out Gmoccapy 3.08.2 on linuxcnc 2.8pre-~ and I can’t seem to get back tool lathe to work.
In Axis, the setting BACK_TOOL_LATHE = 1 works just fine, but in Gmoccapy it has no effect.
I’ve searched the web/forum and haven’t found anyone reporting this issue.
Is this something known?
Thanks,
Ben
02 Jun 2020 09:24 #169782 by bbsr_5a
Replied by bbsr_5a on topic Back tool lathe mode not working
the gemoccapy is as of the master 2.8 rewriten so it may not work on spetial things like you expect
if you like to check if it has worked on gmoccapy from 2.7.15 this woudt give programmers a info on how to solve it in the master
02 Jun 2020 17:11 #169824 by fixer
Replied by fixer on topic Back tool lathe mode not working
I don't think this ever worked correctly.
My proposed fix in glcanon.py is (around line 1800):
lathe_shapes = [
        None,                           # 0
        (1,-1), (1,1), (-1,1), (-1,-1), # 1..4
        (0,-1), (1,0), (0,1), (-1,0),   # 5..8
        (0,0)                           # 9
    lathe_shapes_back = [
        None,                           # 0
        (-1,-1), (-1,1), (1,1), (1,-1), # 1..4
        (0,-1), (-1,0), (0,1), (1,0),   # 5..8
        (0,0)                           # 9
    def lathetool(self, current_tool):
        glDepthFunc(GL_ALWAYS)
        diameter, frontangle, backangle, orientation = current_tool[-4:]
        w = 3/8.
        if '-X' in self.geometry:
            frontangle = 360 - frontangle
            backangle = 360 - backangle
        radius = self.to_internal_linear_unit(diameter) / 2.
        glColor3f(*self.colors['lathetool'])
        glBegin(GL_LINES)
        glVertex3f(-radius/2.0,0.0,0.0)
        glVertex3f(radius/2.0,0.0,0.0)
        glVertex3f(0.0,0.0,-radius/2.0)
        glVertex3f(0.0,0.0,radius/2.0)
        glEnd()
        glNormal3f(0,1,0)
        if orientation == 9:
            glBegin(GL_TRIANGLE_FAN)
            for i in range(37):
                t = i * math.pi / 18
                glVertex3f(radius * math.cos(t), 0.0, radius * math.sin(t))
            glEnd()
        else:
                dx, dy = self.lathe_shapes_back[orientation]
            else:
                dx, dy = self.lathe_shapes[orientation]
            min_angle = min(backangle, frontangle) * math.pi / 180
            max_angle = max(backangle, frontangle) * math.pi / 180
            sinmax = math.sin(max_angle)
            cosmax = math.cos(max_angle)
            tanmax = math.cos(max_angle)
            sinmin = math.sin(min_angle)
            cosmin = math.cos(min_angle)
            tanmin = math.cos(min_angle)
            circleminangle = - math.pi/2 + min_angle
            circlemaxangle = - 3*math.pi/2 + max_angle
            d0 = 0
            x1 = (w - d0)
            sz = max(w, 3*radius)
            glVertex3f(
                radius * dx + radius * math.sin(circleminangle) + sz * sinmin,
                0,
                radius * dy + radius * math.cos(circleminangle) + sz * cosmin)
            for i in range(37):
                #t = circleminangle + i * (circlemaxangle - circleminangle)/36.
                glVertex3f(radius*dx + radius * math.sin(t), 0.0, radius*dy + radius * math.cos(t))
            glVertex3f(
                radius * dx + radius * math.sin(circlemaxangle) + sz * sinmax,
                0,
                radius * dy + radius * math.cos(circlemaxangle) + sz * cosmax)
            glEnd()
        glDepthFunc(GL_LESS)
04 Jun 2020 20:45 - 04 Jun 2020 20:46 #170130 by Schaap
Replied by Schaap on topic Back tool lathe mode not working
I've checked both 2.7.14 and 2.7.15 (with Gmocappy version 1.5.11). With those versions, it works perfectly (doesn't seem to work in Axis GUI)
Back tool lathe mode does seem to work in 2.7.x versions with Gmocappy.
I've tried your proposed fix, but that doesn't seem to resolve it for me in the 2.8 pre
Last edit: 04 Jun 2020 20:46 by Schaap. Reason: more details
12 Aug 2020 16:14 #178043 by newbynobi
Replied by newbynobi on topic Back tool lathe mode not working
Sorry for the delay,
I just pushed a fix to LinuxCNC 2.8 for back tool lathe handling. Now it does work. I checked for the old state of the button and only changed the view of the preview if it was not Y or Y2. So if you would have changed the view once with the Y View button and stopped with that view the screen, it would have been correct. I now just set the preview according to the ini file settings.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.101 seconds
