How to set default jog rate?
31 Dec 2020 13:42 #193650 by newbynobi
Replied by newbynobi on topic How to set default jog rate?
I have found the reason, thanks for reporting this bug.
I have pushed a fix some minutes ago, so gmoccapy 3.1.1 solves this bug.
Norbert
The following user(s) said Thank You: HansU
03 Jan 2021 20:23 #193983 by HansU
Replied by HansU on topic How to set default jog rate?
Great, Thanks!
24 Jan 2021 09:02 #196386 by HansU
I found a simple workaround for the 2.8 version.
Just add
setp gmoccapy.jog.jog-velocity.direct-value 2
to the hal file (even if gmoccapy.jog.jog-velocity.analog-enable is 0).
The value 2 leads to a default velocity of 1/10 MAX_LINEAR_VELOCITY
Moderators: newbynobi, HansU
Time to create page: 0.463 seconds
