switching between world mode and joint mode
02 Aug 2020 04:06 #176858 by ericg
I have got my Mesa 5i25 card going well, I have gmocappy Going well (may swap back as I don't have a touchscreen) and I also have my HB04 pendant going mostly well, the only button that gives an error is the home all button which I like to use after a program is finished so the router is out of the way, however I get the error 'must be in joint mode to home' so the question is, how to I switch from world mode to joint mode? and is there a good explanation of these modes
This is the line in my xhc-HB04.hal file # Home button
net home halui.home-all <= xhc-hb04.button-home
02 Aug 2020 23:41 #176965 by tommylight
Replied by tommylight on topic switching between world mode and joint mode
Moved to Gmoccapy section.
03 Aug 2020 03:49 #176995 by ericg
Sorry tommylight, wasn't sure where this question fitted
03 Aug 2020 08:01 #177009 by Aciera
Replied by Aciera on topic switching between world mode and joint mode
What version of LinuxCNC are you using?
I use gmoccapy with linuxcnc master and also use an external button that connects to halui.home-all. Works fine for me.
03 Aug 2020 08:16 - 03 Aug 2020 08:17 #177012 by ericg
from uname -a I get..
Linux linuxcnc 4.19.0-9-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.118-2+deb10u1 (2020-06-07) x86_64 GNU/Linux
Is linuxcnc Master something I should have?
what is the specific command you use? mine is from xhc-hb04.hal
# Home button
thanks for the response
Last edit: 03 Aug 2020 08:17 by ericg. Reason: added some info
03 Aug 2020 08:41 #177019 by tommylight
No worries, all good, also wanted to bump it up as no one answered.
11 Aug 2020 20:44 #177942 by newbynobi
Replied by newbynobi on topic switching between world mode and joint mode
If you have kinstype=Both in you INI config you should see a button to switch the joint world mode.
If you have keyboard handling enabled on the setting page, F12 should change modes.
If you post your config folder, I can check for config errors.
Norbert
04 Mar 2023 11:25 #265834 by HansU
Like this:
[KINS]
KINEMATICS = trivkins coordinates=xyz kinstype=BOTH
JOINTS = 3
I mention it here, because it is currently not really mentioned in the documentation.
Moderators: newbynobi, HansU
Time to create page: 0.097 seconds
