Edit Jog Buttons
5 years 5 months ago #209049 by newbynobi
Replied by newbynobi on topic Edit Jog Buttons
You are still using the old version.
If you do update you should get 3.1.3.XX
How have you installed your linuxcnc?
If synaptic does not show updates fot linuxcnc, may be you haven't set the sources correct.
Norbert
5 years 5 months ago #209298 by eighthaxis
Replied by eighthaxis on topic Edit Jog Buttons
I am using Debian Stretch rt-preempt
When I try to upgrade with synaptic package manager I get this:Could not download all repository indexes
The repository may no longer be available or could not be contacted because of network problems. If available an older version of the failed index will be used. Otherwise the repository will be ignored. Check your network connection and ensure the repository address in the preferences is correct.
GPG error: linuxcnc.org stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 3CB9FD148F374FEFThe repository ' linuxcnc.org stretch InRelease' is not signed.
I am trying to follow these directions:
linuxcnc.org/docs/html/getting-started/updating-linuxcnc.html
5 years 5 months ago #209303 by newbynobi
Please post a Screenshot from your repository from synaptic
Can you access pages in the internet, as it might be also a network probelm.
What about:
ping www.google.de
Norbert
5 years 5 months ago #209334 by tommylight
Replied by tommylight on topic Edit Jog Buttons
sudo apt-key adv --keyserver hkp://keys.gnupg.net:80 --recv-key EF1B07FEE0EE663E
sudo apt update
5 years 5 months ago #209346 by eighthaxis
Yes I do have internet access and was able to browse without issue.
I will try tommy's suggestion below and get back to you guys.
5 years 5 months ago #209361 by eighthaxis
OK Tommy I tried your suggestion here are the results:
Moderators: newbynobi, HansU
