how to get control panel jog buttons for X Y Z working in gmoccapy
- newbynobi
- Thank you received: 394
29 Sep 2020 20:56 #184326
by newbynobi
Replied by newbynobi on topic how to get control panel jog buttons for X Y Z working in gmoccapy
I will post here if I found a solution
You are welcome ?
You are welcome ?
- BeagleBrainz
- Visitor
29 Sep 2020 21:13 #184329
by BeagleBrainz
Replied by BeagleBrainz on topic how to get control panel jog buttons for X Y Z working in gmoccapy
Here’s an article on using an arduino to act as a USB keyboard.
www.sparkfun.com/tutorials/337
Set it up to send an enter key and you are done. No need for any HAL connections. You can even use it to send key combinations.
- depronman
- Thank you received: 9
30 Sep 2020 18:43 #184404
by depronman
Replied by depronman on topic how to get control panel jog buttons for X Y Z working in gmoccapy
After the slightly bad news from Norbert about currently there being no button to emulate the keyboard enter key, I decided to explore one of your suggestions re hacking a keyboard to get the enter key button onto my control panel
I decided to use the older keyboard connector as I have a few spare ps/2 keyboards.
Once I stripped a keyboard down it was fairly simple to trace the enter button traces on the plastic film to the two appropriate two strips on the circuit board. I soldered wires to these two traces and tested it - perfect worked first time
I also tried a usb keyboard as well as the ps/2 keyboard connector, bingo PC saw them both and linux recognised them both
just goes to show whata littler latteral thinking can come up with - thankyou BB
The following user(s) said Thank You: BeagleBrainz
- depronman
30 Sep 2020 19:08 #184405
by depronman
do you have an example of how I would use the or2 command to allow the use of both the pendant button and the panel buttons
(from the hal file)
net run-btn <= parport.1.pin-10-in-not => halui.mode.auto => halui.program.run
(from the pendant section on ini file)
start-pause = std_start_pause
so, how would I use the or2 command with the above
Thanks in advance
Paul
(from the hal file)
Thanks in advance
Paul
- newbynobi
30 Sep 2020 20:32 #184416
by newbynobi
Just connect parport pin to or.0.in0 and the physical button to or. 0.in1 then or. 0.out to the start pause halui pin.
Do not forget to load with loadrt and connect or also to servo-thread.
All out of memory, so check the Hal pin names etc.
Norbert
Norbert
- BeagleBrainz
- Visitor
01 Oct 2020 01:21 #184441
by BeagleBrainz
Docs are always a good place to start
linuxcnc.org/docs/2.8/html/
The devs have put a lot of effort into the docs, give them a go.
Moderators: newbynobi, HansU
Time to create page: 0.596 seconds
