Script on startup
10 Oct 2020 20:20 #185628 by MatthiasF1210
Script on startup was created by MatthiasF1210
is there a way to execute a nc-file or python script on startup of Gmoccapy after the gui is loaded?
Matthias
  • Moderator
  • Moderator
10 Oct 2020 21:22 #185635 by tommylight
Replied by tommylight on topic Script on startup
It should be possible, for nc file just adding this to the "display" section in the ini file should work:
open_file = name_of_the_file_to_open.ngc
It works with Axis GUI so it should with Gmoccapy.
Should also be possible for python, but i'll leave that to more experienced members here.
10 Oct 2020 22:01 #185649 by MaHa
Replied by MaHa on topic Script on startup
To execute a file, machine must be homed. After homing the last axis, for this axis in the hal file, at
'net n-is-homed halui.joint.n.is-homed' add: halui.mdi-command-nn
In .ini file
[HALUI]
MDI_COMMAND = Mnnn
In the executable Mnnn file your code
(n for axis and numbers)
11 Oct 2020 08:19 #185680 by newbynobi
Replied by newbynobi on topic Script on startup
To hook only one axis homed, it may cause an error, if not all axis are homed. So I would recommend to hook them to something like all_homed, that is the way gmoccapy reloads the tool on start up, Getting the all homed state, gmoccapy executes an MDI Command
Norbert
11 Oct 2020 19:07 #185743 by MatthiasF1210
Replied by MatthiasF1210 on topic Script on startup
Thanks for the hint.
My Ini File:
[HALUI]
MDI_COMMAND = o<startupcheck> call
My Postgui.hal:
net allhomed => halui.mdi-command-00
"allhomed" is calculated from all homeswitches.
But there is one problem left. Since my machine is still moving to the "home" Positionig after homing was done, there is an Error Msg "Change to MDI not possible" Is there a way to place an delay?
thanks
Matthias
12 Oct 2020 06:32 #185802 by newbynobi
Have you tried to include a G4 P5 in your file?
Norbert
12 Oct 2020 12:14 #185821 by andypugh
Replied by andypugh on topic Script on startup
Use an and2 using all-homed and motion.motion-type = 0?
That last condition will be slightly painful, as it's an s32 and needs to be convereted to float to use wcomp to test for zero.
12 Oct 2020 20:05 #185870 by MatthiasF1210
i've done it.
in my hal-file
# -- NC-script on Startup Check with debounce --
loadrt debounce cfg=32,10,1
addf debounce.2 servo-thread
setp debounce.2.delay 1000
net all-homed => debounce.0.0.in
net mdi-cmd-startup <= debounce.0.0.out => halui.mdi-command-00
Matthias
  • Moderator
  • Moderator
12 Oct 2020 21:39 #185885 by tommylight
Hmmm that may also work with timedelay
linuxcnc.org/docs/2.8/html/man/man9/timedelay.9.html
15 Nov 2020 00:23 - 15 Nov 2020 00:24 #189411 by Nitram
Replied by Nitram on topic Script on startup
i've done it.
in my hal-file
Is there a native gmoccapy pin which needs to be connected to the "all-homed" signal, or is it created by using a few and2 components combining all "joint.N.is-homed" pins to create an "all-homed" pin?
Thanks.
Last edit: 15 Nov 2020 00:24 by Nitram.
Moderators: newbynobi, HansU
Time to create page: 0.151 seconds
