Script on startup
- MatthiasF1210
is there a way to execute a nc-file or python script on startup of Gmoccapy after the gui is loaded?
Matthias
- Thank you received: 7481
open_file = name_of_the_file_to_open.ngc
It works with Axis GUI so it should with Gmoccapy.
Should also be possible for python, but i'll leave that to more experienced members here.
- MaHa
- Thank you received: 240
'net n-is-homed halui.joint.n.is-homed' add: halui.mdi-command-nn
In .ini file
[HALUI]
MDI_COMMAND = Mnnn
In the executable Mnnn file your code
(n for axis and numbers)
- newbynobi
- Thank you received: 394
Norbert
- MatthiasF1210
Thanks for the hint.
My Ini File:
[HALUI]
MDI_COMMAND = o<startupcheck> call
My Postgui.hal:
net allhomed => halui.mdi-command-00
"allhomed" is calculated from all homeswitches.
But there is one problem left. Since my machine is still moving to the "home" Positionig after homing was done, there is an Error Msg "Change to MDI not possible" Is there a way to place an delay?
thanks
Matthias
- newbynobi
Norbert
That last condition will be slightly painful, as it's an s32 and needs to be convereted to float to use wcomp to test for zero.
- MatthiasF1210
i've done it.
in my hal-file
# -- NC-script on Startup Check with debounce --
loadrt debounce cfg=32,10,1
addf debounce.2 servo-thread
setp debounce.2.delay 1000
net all-homed => debounce.0.0.in
net mdi-cmd-startup <= debounce.0.0.out => halui.mdi-command-00
Matthias
linuxcnc.org/docs/2.8/html/man/man9/timedelay.9.html
- Nitram
- Thank you received: 15
i've done it.
in my hal-file
Is there a native gmoccapy pin which needs to be connected to the "all-homed" signal, or is it created by using a few and2 components combining all "joint.N.is-homed" pins to create an "all-homed" pin?
Thanks.
