Can't find M1 - optional stop switch
18 Oct 2020 15:46 #186510 by MatthiasF1210
Can't find M1 - optional stop switch was created by MatthiasF1210
another minor issus since my upgrade to 2.8.
The program stops after every section because of M1. This was not the case before....
The documentation says there is an "optional stop switch" to control M1. I can't find the corresponding hal pin in the Docu.
Just in the the forum I found:
in auto mode
gmoccapy.h-button.button-0 == open file
gmoccapy.h-button.button-1 == run
gmoccapy.h-button.button-2 == stop
gmoccapy.h-button.button-3 == pause
gmoccapy.h-button.button-4 == step by step
gmoccapy.h-button.button-5 == run from line if enabled in settings, otherwise Nothing
gmoccapy.h-button.button-6 == optional blocks
gmoccapy.h-button.button-7 == optional stops M1
gmoccapy.h-button.button-8 == full-size preview
gmoccapy.h-button.button-9 == edit code
But the H-Button is not shown either. Is there something in the Ini file to show the Hal Button?
Matthias
18 Oct 2020 21:41 - 18 Oct 2020 21:52 #186543 by tacklem60
Replied by tacklem60 on topic Can't find M1 - optional stop switch
I can second this issue. I resorted to turning off optional stop in my post processor for now so it no longer issues M1 commands in the g code but something definitely got deleted between last version and the 3.0 update of Gmoccapy in 2.8
Last edit: 18 Oct 2020 21:52 by tacklem60.
25 Oct 2020 09:45 #187192 by newbynobi
Replied by newbynobi on topic Can't find M1 - optional stop switch
You are right, the button does not exist any more. Shame on me, that I haven't updated the documentation.
I needed the place of the button, to show a reload file button on the AUTO page, IMHO that one is used more often, that the optional stop button. It might be a good Idea to place such an option on the settings page.
06 Apr 2026 11:00 #345229 by RotarySMP
Replied by RotarySMP on topic Can't find M1 - optional stop switch
I use M1 option stops all the time, to give me time to check things on a new program before continuing to the next thing. This is still implemented on my mills old Gmoccapy installation.
Did turning on/off stops on M1 really get deleted from Gmoccapy? That would be disappointing.
06 Apr 2026 11:55 #345231 by Vegko
Replied by Vegko on topic Can't find M1 - optional stop switch
The M1 button is the one i am actually missing in Gmoccapy.
The space constraint is a hard one, everybody has other needs.
For me personally i would rather skip the full screen toggle, but a total of 11 buttons would fit as well.
06 Apr 2026 12:15 #345236 by RotarySMP
Yeah, I would also happily sacrifice full screen for M1.
Moderators: newbynobi, HansU
Time to create page: 0.124 seconds
