Error during toolchange probe tripped during move
- merlinfive
- Thank you received: 3
09 Nov 2020 14:16 #188751
by merlinfive
Error during toolchange probe tripped during move was created by merlinfive
Hi , I'm getting nuts ,
first of all I'm Newbie , I setup linuxcnc 2.8.0 with gmoccapy 3.0.9.1, mill is working so far , XYZ , limit switches , spindle.
I setup the internal auto tool measurment from gmoccapy .
It moves XYZ to requested position , dialog for tool change is displayed , acknowledged , Z move fast down to requested position and started to slow down for measurement , so far ok.
then If I wait for the MAXPROBE distance without pressing the sensor I get the correct message (G38.2 move finished without making contact)
but if the sensor is pressed I got "Probe is already tripped when starting G38.2 or G38.3 move"
any help appreciated
- merlinfive
10 Nov 2020 16:19 #188893
by merlinfive
Replied by merlinfive on topic Error during toolchange probe tripped during move
ok , got it fixed , I use my "switches" for both limit and home ,
so my Z min MAX is 0 and home -5 , switches at -2.
in the macro (manual_change) was
;first go up
G90
G53 G0 Z[#<_ini[AXIS_Z]MAX_LIMIT>-0.1]
so 0-0.1 =G53 -0.1 but my switches were already triggered at -2
;first go up
G90
G53 G0 Z[#<_ini[AXIS_Z]MAX_LIMIT>-10.0] fixed the problem
;first go up
G90
;first go up
G90
Moderators: newbynobi, HansU
Time to create page: 0.208 seconds
