- Thank you received: 2177
Remotely control Machine on button
Do you want to connect the estop screen button or the machine on/off screen button?
My suggestion was actually for a momentary switch attached to one of your cards inputs to control machine on/off (machine enable) . Press and release enables the machine, press and release again disables the machine.
halui.machine.on / -.off is a bit special as it has two complementary inputs that take impulses.
- newbynobi
- Thank you received: 394
OK now here are both solutons named here
Norbert
- Thank you received: 7491
- rogerfries
- Thank you received: 4
Perhaps I'm not stating my question correctly. Basically I don't want the LinuxCNC power button, so I'm trying to automate it. I want the power button to automatically change to reflect the e-stop status. By default Linux CNC turns the power button off when the machine e-stops. So when the machine comes out of e-stop I want to send a signal to automatically turn the LinuxCNC software power button on. Turning it Green and unlocking the controls. I don't want to rewire the machine to have a momentary button as Aciera suggests. and my stock HAL file already matches Norbert's post.
If I understand correctly (and I probably don't) the below line enables the machine when it comes out of estop
net estop-ext => iocontrol.0.emc-enable-in
So I want to enable the machine and turn on the power button so I want something like the below, but it does not work
net estop-ext => iocontrol.0.emc-enable-in => hal.ui.machine.on
I doubt there is anything relevant in my config, but it's available github.com/rogerfries/Boss5.git
This whole power button thing is really a minor annoyance, but I think Learning how to do this will be important to help me learn how HAL works for my future objectives. I want to add a bunch of buttons to make a control panel and a touch plate tool height setter.
Roger
- bevins
- Thank you received: 338
rogerfries wrote: Hi Again,
Roger
It's not hal.ui it is halui
You may have an issue because estop has to be reset before turning the machine on. You can try setting a delay after the estop reset then turning on the machine.
- rogerfries
Thanks for pointing out my typo, but the root issue is there can only be one output. I get the error "halui.machine.on was already linked to signal estop.ext".
Roger
