Dynamic tool messurment macro abort oftens at the same step
22 Nov 2020 01:05 #190018 by DanielSun
Hi together,
my name is Daniel and I have a problem with my gmoccapy.
At first I love gmoccapy :-)
All runs but I have a Problem with a macro.
The macro works great and is from Talla83.
With axis, it works.
With gmoccapy it sometimes (2 or 3 times) at this position.
G53 X#1801 Y#1802 (Taster Position)
It's the moment after the machine goes to toolchange position and i confirme the toolchange then comes the line
but then it stops there.
I inserted a G4 P0.01 for the line but it doesn't help.
Has somebody an Idea or can help me?
If necessary I can make a video of the problem.
I searched here in the forum and on google but i found nothing :-(
Best wishes
Daniel
o<messen> sub
#1700=153		(Wechsel X Position)
#1701=-2071		(Wechsel Y Position)
#1702=-30		(Wechsel Z Position)
#1800=-90		(Position sicheres Z)
#1801=77.25		(Position Taster X)
#1802=-2504.81		(Position Taster Y)
#1900=#<_coord_system>	(NP merken nur G54 bis G59)
o500 if [#<_current_tool> EQ #<_selected_tool>]
;(debug, Tool bereits in der Spindel)
o500 else
M5
G54
G90 G0
G53 Z#1702	   	 (Wechsel Z Position)
G53 X#1700 Y#1701   	 (Wechsel XY Position)
M6 T#<_selected_tool>
G4 P0.01
G53 Z#1800	   	    (Sichere Z Position)
G43.1 Z0	   	 (TLO reset)
G91
G38.2 Z-60  F500   	 (messen grob)
G1    Z1.0  F500   	 (frei fahren)
G38.2 Z-10  F25    	 (messen fein)
#2000=[#5063+#5223]	 (Tastpunkt+NP Verschiebung)
#2001=[#2000-#2002+#2003](Neu - diff + alt)
#2002=[#2000]      	 (Tastpunkt alt merken)
#2003=[#2001]	   	 (Offset alt merken)
G1 Z5.0 F500       	 (frei fahren)
G90 G0
G43.1 Z#2001       	 (TLO set)
;(debug, Differenz ist: #2001)
(NP wiederhestellen nur G54 bis G59)
o100 if[#1900 EQ 540]
G54
o100 endif
o101 if[#1900 EQ 550]
G55
o101 endif
o102 if[#1900 EQ 560]
G56
o102 endif
o103 if[#1900 EQ 570]
G57
o103 endif
o104 if[#1900 EQ 580]
G58
o104 endif
o500 endif
o<messen> endsub
M2
25 Nov 2020 21:42 #190295 by newbynobi
I do not think it is the G53 move, but one command earlier.
Could you please try to change M6 T#<_selected_tool> to be a two line command
T#<_selected_tool>
M6
And check the Hal pin for the tool change with Hal view?
Norbert
25 Nov 2020 22:02 #190296 by Hakan
Can it be that the motion mode G0/G1 is forgotten at tool change M6?
Try with G53 G0 X#1801 Y#1802
Moderators: newbynobi, HansU
